Error with switch 2960
Hi all ,
This error is appeared on switch 2960 i need to know what this error ?
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/5: Power given, but Power Controller does not report Power Good
balaji.bandi
is this only port having issue ?
what version of code running also post show version and show power inline
also check below thread :
https://community.cisco.com/t5/switching/controller-port-error/td-p/2876390
BB
Admin-4#show cable-diagnostics tdr int gigabitEthernet 1/0/1
TDR test last run on: August 31 15:57:14
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/1   auto  Pair A     33   +/- 1  meters N/A         Short
                Pair B     33   +/- 1  meters N/A         Short
                Pair C     34   +/- 1  meters N/A         Short/Crosstalk
                Pair D     34   +/- 1  meters N/A         Short/Crosstalk
Faulty cable at the far end.
Dear ,
Kindly be informed that this issue is related to some ports not all ports and  the phone is directly connected to the switch
Admin-4 uptime is 15 weeks, 5 days, 18 hours, 24 minutes
System restarted at 21:38:29 EEST Fri May 12 2023
System image file is "flash:c2960s-universalk9-mz.150-1.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960S-24PD-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1438Y0YA
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
26 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-xxx
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 6C:50:4D:6C:07:80
Motherboard assembly number     : 73-12427-07
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC14374WAX
Power supply serial number      : DCA1424U1WS
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24PD-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC1438150R
System serial number            : FOC1438Y0YA
Top Assembly Part Number        : 800-32456-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMFF10BRB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24PD-L   15.0(1)SE             C2960S-UNIVERSALK9-M
Configuration register is 0xF
Admin-4#show
Admin-4#show powe
Admin-4#show power in
Admin-4#show power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           370.0       90.5       279.5
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   faulty     0.0     n/a                 n/a   30.0
Gi1/0/2   auto   on         6.3     IP Phone 7942       2     30.0
Gi1/0/3   auto   on         6.3     IP Phone 7942       2     30.0
Gi1/0/4   auto   on         6.3     IP Phone 7942       2     30.0
Gi1/0/5   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/6   auto   on         6.3     IP Phone 7942       2     30.0
Gi1/0/7   auto   on         5.0     IP Phone 7911       2     30.0
Gi1/0/8   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/9   auto   off        0.0     n/a                 n/a   30.0
Gi1/0/10  auto   on         3.3     IP Phone 7821       1     30.0
Gi1/0/11  auto   on         12.0    IP Phone 7965       3     30.0
Gi1/0/12  auto   on         5.0     IP Phone 7911       2     30.0
Gi1/0/13  auto   on         5.0     IP Phone 7911       2     30.0
Gi1/0/14  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/15  auto   on         5.0     IP Phone 7911       2     30.0
Gi1/0/16  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/17  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/18  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/19  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/20  static faulty     0.0     n/a                 n/a   30.0
Gi1/0/21  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/22  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/23  auto   off        0.0     n/a                 n/a   30.0
Gi1/0/24  auto   off        0.0     n/a                 n/a   30.0
Admin-4#
