Errors and link flaps on fibre (fiber) trunk
Andrew Devine
I have setup a trunk between a WS-X4306-GB line card and a dual-media uplink port on a WS-CBS3020-HPQ blade switch. However, when I enable the port it flaps every minute or so and after the flap reports runts on the interface.
  • The WS-X4306-GB line card is installed in mod 9 of a 4510R-E running IOS 12.2(46)SG (cat4500e-ENTSERVICESK9-M), a 1000BASE-SX GBIC (WS-G5484) is installed in Gi 9/1
  • The WS-CBS3020-HPQ blade switch is running 12.2(40)SE2 (CBS30X0-LANBASE-M) and has a 1000BASE-SX SFP (GLC-SX-MM) installed into port Gi 0/17
  • The fibre connection goes via a patch panel
  • 62.5/125 and 50/125 fibre has been tried but with the same result for both types
Config:-
! STP port-priority configured so I can enable new uplink without affecting STP topology, copper uplinks existing
4510R-E#sh run int gi 9/1
interface GigabitEthernet9/1
switchport mode trunk
udld port aggressive
spanning-tree port-priority 144
! Uplinkfast enabled so I can control root port by altering 9/1 STP port priority out of hours, link state group on all uplinks to bring blade NICs down
3020#sh run int gi 0/17
interface GigabitEthernet0/17
link state group 1 upstream
Outputs:-
4510R-E#sh int gi 9/1 contr
GigabitEthernet9/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 0022.bddd.48b6 (bia 0022.bddd.48b6)
Description: 3020 Gi0/17
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Last input 21:03:48, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1310747 packets input, 1293130218 bytes, 0 no buffer
Received 4965 broadcasts (4504 multicasts)
2 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
5931346 packets output, 1660789456 bytes, 0 underruns
0 lost carrier, 0 no carrier
4510R-E#sh int gi 9/1 capabilities
GigabitEthernet9/1
Model: WS-X4306-GB-Gbic
Type: 1000BaseSX
Speed: 1000
Duplex: full
Auto-MDIX: no
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100), hw
Multicast suppression: percentage(0-100), hw
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
VLAN Membership: static, dynamic
Fast Start: yes
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
SPAN: source/destination
UDLD: yes
Link Debounce: no
Link Debounce Time: no
Port Security: yes
Dot1x: yes
Maximum MTU: 9198 bytes (Jumbo Frames)
Multiple Media Types: no
Diagnostic Monitoring: N/A
Queuing: rx-(N/A), tx-(1p7q1t)
3020#sh int gi 0/17 controller
GigabitEthernet0/17 is administratively down, line protocol is down (disabled)
Hardware is Gigabit Ethernet, address is 0022.91af.9a11 (bia 0022.91af.9a11)
Description: 4510R-E Gi9/1
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input 21:06:47, output 21:06:47, output hang never
Last clearing of "show interface" counters 21:20:17
1133530 packets input, 783706915 bytes, 0 no buffer
Received 4791 broadcasts (12215 multicasts)
2166 runts, 0 giants, 0 throttles
2166 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 12215 multicast, 0 pause input
302 packets output, 35116 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
Transmit GigabitEthernet0/17 Receive
1474443247 Bytes 2002996525 Bytes
1316622994 Unicast frames 45790944 Unicast frames
90800633 Multicast frames 1047999 Multicast frames
71657260 Broadcast frames 410590 Broadcast frames
0 Too old frames 1693481132 Unicast bytes
2167069 Deferred frames 236924556 Multicast bytes
0 MTU exceeded frames 45180464 Broadcast bytes
862378 1 collision frames 0 Alignment errors
2398 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 63932 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 12648203 Minimum size frames
0 8 collision frames 4929545 65 to 127 byte frames
0 9 collision frames 5811136 128 to 255 byte frames
0 10 collision frames 342125 256 to 511 byte frames
0 11 collision frames 1252505 512 to 1023 byte frames
0 12 collision frames 22266019 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
163200 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
645753757 64 byte frames 63932 Valid frames, too small
296775985 127 byte frames
135004286 255 byte frames 0 Too old frames
66860049 511 byte frames 0 Valid oversize frames
134507717 1023 byte frames 0 System FCS error frames
200245716 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
862378 Good (1 coll) frames
2398 Good (>1 coll) frames
4510R-Esh int gi 0/17 capabilities
GigabitEthernet0/17
Model: WS-CBS3020-HPQ
Type: 1000BaseSX SFP
Speed: 1000
Duplex: full
Trunk encap. type: 802.1Q,ISL
Channel: yes
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),tx-(4q2t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
PortSecure: yes
Dot1x: yes
Multiple Media Types: rj45, sfp, auto-select
Aug 10 12:17:02 BST: %LINK-3-UPDOWN: Interface GigabitEthernet0/17, changed state to up
Aug 10 12:17:05 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:17:41 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Aug 10 12:17:44 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:17:58 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Aug 10 12:18:01 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:19:11 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Aug 10 12:19:14 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:19:41 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Aug 10 12:19:44 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:22:12 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Aug 10 12:22:15 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
Aug 10 12:22:20 BST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
Any help appreciated, I intened to run a direct cable to rule out the patch panel once I've sourced one long enough.
Cheers,
Andrew
17 Replies 17
Leo Laohoo
That't not good.  Change the GBIC on the 3020 and see what happens.
I did try swapping the SFP, I notice the relaiability is 255 on the parallel switch in the blade chassis.
I had the exact same issue with both blade switches so implies a common issue.
3020-2#sh int gi 0/17
  Hardware is Gigabit Ethernet, address is 0022.91af.b511 (bia 0022.91af.b511)
  Description: 4510R-E Gi9/2
  Keepalive not set
  Last input 1d15h, output 1d15h, output hang never
     90237 packets input, 36657846 bytes, 0 no buffer
     Received 1209 broadcasts (3518 multicasts)
     15 runts, 0 giants, 0 throttles
     15 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3518 multicast, 0 pause input
     82074 packets output, 75563958 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
Which is wierd because even though the port is ADMINISTRATIVELY DOWN the reliability is 254/255.  The value changes so it doesn't mean that it stays that way.  It was just good that you punched the command in when the value went down.
What IOS are both switches running?
All defined in the bullet points above...
Did you change the patch cable?
Tried 62.5/125 and 50/125 fibre, same result.  Thinking possibly patch panel or maybe dirty GBICs/SFPs
Don't believe the rx/tx load value: older IOSes on CBS3020 have a known bug (sorry don't have the bugid at hand) where the interface bandwidth is incorrectly reported as 10mbps instead of 1gig.
See from your own output:
Since the load values are calculated based on the bandwidth value, they are wrong.
You can either upgrade to a newer IOS or set the bandwidth parameter manually on all interfaces (this only affects the reported bandwidth...).
amikat
Will you please check via the "show udld" command that UDLD message timer (interval) is set to the same value at both ends.
Best regards,
Antonin
4510R-E#sh udld gi 9/1
Interface Gi9/1
Port enable administrative configuration setting: Enabled / in aggressive mode
Port enable operational state: Enabled / in aggressive mode
Current bidirectional state: Unknown
Current operational state: Link down
Message interval: 7
Time out interval: 5
No neighbor cache information stored
3020#show udld gi 0/17
Interface Gi0/17
Message interval: 7
Are you using "GLC-SX-MM" for the SFP on your 3020?
Jonathan,
Yup
3020#show int gi 0/17 transceiver properties
Diagnostic Monitoring is not implemented.
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: auto
Operational Duplex: auto
Operational Auto-MDIX: on
Media Type: 1000BaseSX SFP
Configured Media: auto-select
Active Media: sfp
I did notice you keepalive setting don't match between devices and try hard coding your duplex on your 3020.
Keepalive not set
Jonathan,
I though ethernet keepalives were only locally significant?
there is no option to configure speed/duplex on any of the interfaces, the GBIC and SFP are pinned to 1000/Full.
The default for SFP interfaces is no keepalive
To my knowledge (which does have potholes), having no keepalive on an interface will trick the device to believing the interface is up when actually there is no distant end connection.  I am a fan of uniformity when it comes to Cisco configs.  When possible make you P2P match.  I have several 4510R-E's.  My WS-X4624-SFP-E's are set to "Full" duplex and "1000" speed, no other options available.  But on my WS-X4148-FX-MT's I have an option of "Full" or "Half" duplex.  Strange, that your 3020 is showing "Auto" for the duplex.
Jonathan,
