03-19-2012 10:34 PM - edited 03-07-2019 05:40 AM
Hello Community!
We got a really strange problem here. We've got one cisco ESW 520 switch and one HP. Whoever's connected on the ESW switch cannot connect to pop.gmail.com port 995. Everything else is OK! Internet, pings, whatever. ONLY cannot access pop.gmail.com port 995. Even gmail.com comes up fine. When we move the computers to the HP switch pop.gmail.com comes up fine.
We've looked and looked and cannot find any solution. We're thinking this is a new issue, because one of our friends who works at another company is experiencing the same issue. Anyone connected to their ESW switch cannot access pop.gmail.com:995.
WHAT'S GOING ON??
Appreciate any input!
Solved! Go to Solution.
03-22-2012 02:56 PM
There is a work around that has fix the issue for now, Cisco has informed me that they are still working on the right solution.
A working around is to login the ESW switch and navigate to ‘policy binding’ and disable DSCP policy binding on the ESW switch.
just select all and delete, it has worked for me and no issue has came up yet. It has been 2 hrs now.
03-20-2012 03:16 AM
Hi, for clients on the 520 and on the HP, do you use the same dns servers for the clients?
03-20-2012 09:18 AM
Yes
Connected by DROID on Verizon Wireless
03-22-2012 02:32 PM
Hello
I had the same problem, I open a Cisco Case, they told me upgrade de IOS to newest version, and nothing the same problem. I resolve this issue with changing from Phone + PC to Switch profile.
03-22-2012 02:57 PM
A customer of ours got one Cisco SMB Tech who told him to remove each DCSP Policy Binding on each Interface under the Advanced -> Policy Bindings settings and it worked.
03-22-2012 02:56 PM
04-03-2012 02:57 PM
I just wanted to say, this was an issue I had been having with Gmail IMAP and SMTP going through ports on this switch to a UC520 thanks for posting this resolution! I couldn't freagin understand how every other computer in the office was working through another switch to the UC but these handfull going through this ESW were incimunnicado only on 993 and 587 over TLS. I was scouring the place looking for any similarities to my system...
Now if I can just get the damn SG200-08P to talk tot he network I'll be in good shape... but thats for anothr thread
Thanks George Tu
04-13-2012 12:54 PM
Hello Everyone,
Does it cause any problems to voice calls, I had the same problem and I followed the same procedure. The policy map was voice-map earlier and I have deleted now. I have cisco ip phones connected to switch and computers to the switch port of IP phones. Does changing policy bindinng affect voice phone calls?
Thanks in advance.
