Ether Channel Blocking Port?
keithhampshire
I'm trying to learn about ether channel on 3 cisco switches. All switch have ether channel configured on 2 of their ports. My question is, after configuring all the switches to use ether channel on the 2 ports I have a set of ports that are "blocking".  See image and the "show spann" command below.
Why did these set of ports decide to go into a blocking state?
Switch#sh spann
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 0003.E4B9.3191
Cost 9
Port 27(Port-channel1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 0060.2F83.1379
Aging Time 20
Interface Role Sts Cost Prio.Nbr Type
Po1 Root FWD 9 128.27 Shr
Po2 Altn BLK 9 128.28 Shr
Giuseppe Larosa
Hello @keithhampshire ,
what you see is normal and it is the result of STP action.
You have a full mesh made of etherchannel links. STP treat each port-channel as a single link but STP still needs to break the loop so in your case on one switch likely the one with the worst Bridge ID one port is the root port = port to the STP root bridge and the other port is an alternate blocking to avoid the loop.
If the root port fails (both member links ) the alternate port will be promoted to root port.
STP allows to use all member links in a port-channel but only if the logical port will be in forwarding state after STP root bridge election and choice of root ports on ech switch.
In your case one side needs to be blocked by STP or you have a loop.
Hope to help
Giuseppe
Deepak Kumar
This port-channel (ports) are blocked by the Spanning-tree protocol to prevent the layer 2 loops.
I think it is better to read this document: https://www.computernetworkingnotes.com/ccna-study-guide/layer-2-switching-loops-in-network-explained.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
