Ether channel.......
Robo123
Hi Team,
As i am facing the below issue in my SF-300 switch.
Snmp and etherchannel not working
1) I want to know whether this switch will support the above mentioned features. If so which version will support. Please share proper cisco documents for the same.
Julio E. Moisa
Im not sure if that model support that but you can verify through this Cisco tool
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Verify platform, product code or image.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yachay
hi Team,
Kindly clarify how we can check the features supported for the SF 300 switch version.As the version will be like below for mat.
Eg:-
sh ver switchf7de30#sh version
SW version 1.1.2.0 ( date 12-Nov-2011 time 23:34:26 )
Boot version 1.1.0.6 ( date 11-May-2011 time 18:31:00 )
HW version V02
 is there any tool available to check the same ?
 Ref:- https://supportforums.cisco.com/t5/small-business-switches/sf300-lag-port-doesn-t-work-lacp-will-not-enable/td-p/1659129
Please suggest on the above.
Hi Yachayv and Julio,
Thanks for the response.
As i am facing the below issues.
1)I am not able to configure Etherchannel. Also when we are
      configuring SNMP string we are unable to get the device in our
      Monitoring tool solar wind. With the same config on another Cisco
      device we are getting in Solarwind.
2) It is a new configuration we
      could not find any command for etherchannel.
3) other end the it is connected to WS-C3750G-24TS-E1U
4) The device is running with
SW version    1.3.0.62 ( date  02-May-2013 time  14:55:01 )
18:31:00 )
                 HW version    V03
Please check and suggest on the above.
