01-30-2008 07:06 AM - edited 03-05-2019 08:49 PM
Please advise - on 3560, can I configure as one etherchannel members the two different types of ports - Gigabit SFP and regular FastEth?
Many thanks!
-ismith
01-30-2008 07:14 AM
No I think you can configure EtherChannel with up to eight Ethernet ports of the same type
M.
01-30-2008 07:30 AM
As Milan said, the speed and duplex need to be the same to form an etherchannel.
Attached is a link that describes all the restrictions when creating an etherchannel
Jon
01-30-2008 07:37 AM
Thanks for your response.
If I limit the speed on the Gig interface to 100meg, will I be able to form an eth-ch with this interface and a normal FastEth?
-ismith
01-30-2008 11:22 AM
Yes it should work if you limit the speed so that they are equal on each each .
