Etherchannel and trunk
qwertys21
Hi All
Can I still configure these connections between the stack swiches (2 x 3750) and the 2960s as etherchannels and trunk?
And if I can do etherchannel, is this set up regarded as cross stack thereby I have to set the etherchannel as "on"
jorg.ramakers
Yes i think it can as the stack is been seen as 1 logical unit. If it is not stacked with a stackwise cable, i don't think it can as cisco doesn't support spilt channeling.
J.
glen.grant
If its cross stack you would use on or active as I believe it will support LACP for cross stack. Does not support PAGP for cross stack etherchannel.
