ā08-07-2012 02:49 AM - edited ā03-07-2019 08:11 AM
I try to connect a cisco blade switch 3020 to Nexus 2232 with etherchannel, but when I connect the second link a obtain flapping on vlans !
Aug 7 09:06:30.569 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0050.565c.0e6a in vlan 100 is flapping between port Gi0/18 and port Gi0/17
Aug 7 09:06:31.140 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 001c.58e3.e38c in vlan 101 is flapping between port Gi0/18 and port Gi0/17
Can someone help me why the vlans are flapping ? it's something wrong on the config ?
thx in advance
Chris
-->NEXUS config
interface port-channel6
switchport mode trunk
spanning-tree bpdufilter enable
speed 1000
duplex full
interface Ethernet102/1/1
speed 1000
duplex full
channel-group 6
interface Ethernet103/1/1
speed 1000
duplex full
channel-group 6
-->Blade switch config :
interface Port-channel2
switchport nonegotiate
end
interface GigabitEthernet0/17
media-type rj45
duplex full
channel-group 2 mode active
end
interface GigabitEthernet0/18
media-type rj45
speed 1000
duplex full
end
Solved! Go to Solution.
ā08-07-2012 04:24 AM
but sorry what is the difference between mode active and ON ?
When you say "channel-group BLAH mode ON" it is NEITHER LACP nor PAGP.
Your Nexus configuration states a default value but your 3020 has stated ACTIVE. This is a configuration mismatch.
Can I ask if you can mark this thread as "Answered"?
ā08-07-2012 02:55 AM
Host with MAC address of "0050.565c.0e6a" is a VMware.
Host with MAC address of "001c.58e3.e38c" is Cisco.
MAC is flapping into two different interfaces possibly because your eitherchannel may not be UP.
On the 3020, can you please post the output to the command "sh etherchann 6 summary"?
ā08-07-2012 03:03 AM
On the 3020,
sh etherchannel 2 summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
2 Po2(SD) LACP Gi0/17(I) Gi0/18(D)
ā08-07-2012 03:07 AM
That answers the question.
"I" means it's in "stand alone" and not in etherchannel. "D", of course, means DOWN.
In your 3020, can you change the etherchannel config to the following?
interface range G0/17 - 18
switchport trunk encap dot1q
channel group 2 mode ON
ā08-07-2012 04:19 AM
ok, now I have change on both and the result is :
d - default port
2 Po2(SU) - Gi0/17(P) Gi0/18(P)
THANK YOU VERY MUCH !
ā08-07-2012 04:28 AM
1000 THANKS
Best Regards
Christophe
ā08-07-2012 03:54 PM
Glad to be of some form of assistance.
