Etherchannel configruation
ssweehinlew
The port link aggregation is not working between Cisco switch and Juniper switch. Below is the configuration. Anything not right? Please advise. Many thanks.
Cisco:
interface FastEthernet0/21
 switchport mode trunk
 channel-group 1 mode active
interface FastEthernet0/22
interface Port-channel1
Juniper:
  ge-0/0/46 {
        enable;
        ether-options {
            802.3ad ae0;
    ge-0/0/47 {
        enable;
        ether-options {
            802.3ad ae0;
   ae0 {
        mtu 1500;
        aggregated-ether-options {
            lacp {
                passive;
                periodic fast;
        unit 0 {
            family ethernet-switching {
                port-mode trunk;
                vlan {
                    members all;
16 Replies 16
devils_advocate
Level 7
Level 7
How do you mean 'not working'?
Are the ports not coming up at all?
Yes. The port is not coming up at all. No light on the port.
Okay first thing first:-
1-does the link between the devices comes up without the other channel configuration?
If the answer is no, then I would first suggest to look the later issue the port light is not coming up means some issue with layer 1.
no issue on layer 1. The link can come up without etherchannel configuration.
Can you check these ports are indeed going to the same Juniper box. By mistake if any cabling error, the ports won't join Port-channel.
What does the log say on cisco when you do this?
Madhu
No finding from the logs even I turned on the "debug lacp all"
Did you check the cabling?
Also try only adding one port to the channel and see single port comes up in the channel.
I have done all the layer 1 checking like cabling, port and etc...
Check the below under cisco to see LACP packets are send or received
sh lacp counters
Also share me  the below
sh lacp internal detail
Below is the output:
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 4
Actor (internal) information:
          Actor                 Actor                       Actor
Port      System ID             Port Number     Age         Flags
Fa0/21    32768,001f.6ce6.0780  0x17            780s        SA
          LACP Actor           Actor           Actor
          Port Priority        Oper Key        Port State
          32768                0x4             0x45
          Port State Flags Decode:
          Activity:   Timeout:   Aggregation:   Synchronization:
          Active      Long       Yes            No
          Collecting:   Distributing:   Defaulted:   Expired:
          No            No              Yes          No
 --More--                   Actor                 Actor                       Actor
 --More--         Port      System ID             Port Number     Age         Flags
Fa0/22    32768,001f.6ce6.0780  0x18            781s        SA
          32768                0x4             0x45
          Active      Long       Yes            No
          No            No              Yes          No
Switch#sh lacp counter
Switch#
Can you please try
lacp rate fast
under these interfaces
Madhu
Just found out that the port speed need to be set to 100 mbps from juniper switch in order to make it up and running. Thank you for the help.
Glad you got it sorted, more often than not it turns out to be something simple!
