Etherchannel configruation
ssweehinlew
The port link aggregation is not working between Cisco switch and Juniper switch. Below is the configuration. Anything not right? Please advise. Many thanks.
Cisco:
interface FastEthernet0/21
 switchport mode trunk
 channel-group 1 mode active
interface FastEthernet0/22
interface Port-channel1
Juniper:
  ge-0/0/46 {
        enable;
        ether-options {
            802.3ad ae0;
    ge-0/0/47 {
        enable;
        ether-options {
            802.3ad ae0;
   ae0 {
        mtu 1500;
        aggregated-ether-options {
            lacp {
                passive;
                periodic fast;
        unit 0 {
            family ethernet-switching {
                port-mode trunk;
                vlan {
                    members all;
16 Replies 16
williamsdo
Level 3
Level 3
Hi,Can the Juniper switch port be set to channel-group mode active? Active - Active should form a etherchannel. You have no port lights, have you tried bouncing the port channel interface? You might try using the channel-protocol command it just enabled the interface in LACP mode only.
much luck
interface gig1/0/47
channel-protocol lacp
channel-group 4 mode active
I just set the juniper switch to LACP active mode and reboot the switch. It is still the same.
