Etherchannel configuratio betwenn SWITCH VSS and ISR Router
habouzyad
Hello all,
I have in my data cneter the following :
1- Two Switchs 45XX configured AS VSS.
2- We have a vlans configured and each vlans has its own SVI.
3- ISR ROUTER with 2 interface G.
We want connect this router to the both Swithcs using etherchannel (LACP). This Router will be connected to vlan ( exemple vlan2). This router must have an ip addresse on the VLAN2.
Would somoene help to did this configuration.
Thank you in advance
Best regards
CHAM
Reza Sharifi
You can just connect the router with 2 interfaces (one to each VSS chassis) (no PO) and use 2 /30 subnets with routed ports on the 45xx VSS.
