Etherchannel Issue with 4506E and 3750X
mannygawadcco
I am having issue with network connectivity in the ether channel configuration between 4506E and 3750X.
Here is the 4506E etherchannel configuration
Cisco 4506E configuration
CORESW#show run int t1/4/1
Building configuration...
Current configuration : 89 bytes
interface TenGigabitEthernet1/4/1
switchport mode trunk
channel-group 1 mode on
end
CORESW#show run int t2/4/1
interface TenGigabitEthernet2/4/1
end
CORESW#show run int po1
Current configuration : 113 bytes
interface Port-channel1
description <<<CONNECTION TO SERVICE BLDG1>>>
switchport
end
CORESW#show etherchannel
CORESW#show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 5
Number of aggregators: 5
Group Port-channel Protocol Ports
1 Po1(SD) - Te1/4/1(D) Te2/4/1(D)
2 Po2(SD) - Te1/4/2(D) Te2/4/2(D)
3 Po3(SD) - Te1/4/3(D) Te2/4/3(D)
 I have the same configuration in 3750X with stack configuration.
i was able to make it up, can someone tell me about the issue?
-manny
That means it's not a configuration error but a Layer 1 issue.
7 Replies 7
mannygawadcco
i also seeing the below message in the debug
"FEC: pagp_switch_reset_cannot_bundle_ports: group 1"
Also note that the 4506E is running is VSS mode
I want to see the configuration from the 3750X.
I also want to see the output to the command "sh interface <PORT> trunk".
3750X
int t1/1/1
switchport
switchport trunk encap dot1q
no shut
int t1/1/2
switchport
no shut
int po1
switchport
no shut
CORESW#show interfaces t1/4/1 trunk
Port Mode Encapsulation Status Native vlan
Te1/4/1 on 802.1q other 1
Port Vlans allowed on trunk
Te1/4/1 none
Port Vlans allowed and active in management domain
Te1/4/1 none
Port Vlans in spanning tree forwarding state and not pruned
Te1/4/1 none
CORESW#
CORESW#show interfaces po1 trunk
Po1 on 802.1q other 1
Po1 none
Po1 none
Po1 none
CORESW#
If you remove the Etherchannel config, do the port go up?
No, the port didn't go up!
i even configured ports into the default one but still im not seeing any luck.
