etherchannel load balance algorithm
Ibrahim Jamil
Level 7
Level 7
Hi Experts
when y have L2 Port-channel between two catalyst switch , which etherchannel load balance algorithm is preferred?
thanks
jubrilak
Community Member
It depends on the whole setup and the most frequent pattern of traffic. But I think per destination or Source MAC address will work fine.
what about the src-dst-ip???
I don't think there is difference between src-dst-ip or src-dst-mac in terms of functionality, either of them is a good one to use but again it depends on your network setup.I believe the defualt is src-dst-mac
Siddhartha
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Whichever one gives the best number of changing values for your traffic's flows.  Often src-dst-IP works well in most cases as it handles traffic to/from hosts on the same L2 network (except between the same two hosts, for those port number help), it handles traffic to/from a host on the L2 network, and it handles traffic that transits the L2 network (e.g. router to router).  An even better mix is 6500 VSS's src-dst-mixed-ip-port.
