etherchannel port aggregation
prashantdwivedi
Why the maximum total no 8 port(cable) can be loggicaly bundled in etherchannel?
Calin C.
Level 5
Level 5
I'm not 100% sure about this, but I think the number is 8 ports, due to load-balancing formula. The port is selected using a Cisco-proprietary hash algorithm, based on  source or destination MAC addresses, IP  addresses or TCP and UDP port numbers. The hash function gives a number between 0 and 7, and the  following table shows how the 8 numbers are distributed among the 2 to 8  physical ports. In the hypothesis of real random hash algorithm, 2, 4  or 8 ports configurations lead to fair load-balancing, whereas other  configurations lead to unfair load-balancing:
Number of Ports Load Balancing
81:1:1:1:1:1:1:1
72:1:1:1:1:1:1
62:2:1:1:1:1
52:2:2:1:1
42:2:2:2
33:3:2
24:4
I hope this helps you!
Cheers,
Calin
The limit of eight ports in an EtherChannel bundle is a restriction imposed by some network hardware and protocols. It's not a fundamental limitation of EtherChannel itself but rather a practical constraint based on implementation and design considerations.
Here are a few reasons why this limit might exist:
Protocol Limitations: Some EtherChannel protocols, like PAgP (Port Aggregation Protocol) and LACP (Link Aggregation Control Protocol), may have limitations on the maximum number of ports allowed in a bundle. For instance, some implementations might support up to 8 ports per bundle.
Hardware Constraints: Switch hardware may have limitations on the number of ports that can be aggregated into a single logical bundle due to processing power, memory, or other hardware-specific factors. Even if the protocol supports more ports, the hardware might not.
Efficiency and Management: Managing large EtherChannel bundles with a high number of ports can become complex and may not provide significant benefits in terms of bandwidth aggregation beyond a certain point. It's often more efficient to deploy multiple smaller EtherChannel bundles rather than a single large one.
Network Design: From a network design perspective, having too many ports in a single EtherChannel bundle can lead to a lack of redundancy and increase the risk of a single point of failure. Distributing ports across multiple smaller bundles provides better fault tolerance and scalability.
For both LACP and PAgP you can bundle 16 ports into an etherchannel, however only 8 ports will be active. So if one of the 8 ports goes down the Etherchannel process will pick a new port to take its place keeping 8 ports in the bundle and active.
Hope that helps
-David
