etherchannel portconfiguration
csaravanan-sym
Hi All,
I have a simple etherchannel configuration
I configured ports gi 0/2/1 and gi 0/2/2  as channel-group 21 mode active
and then configured int po21 as trunking
The ports gi 0/2/1 and gi 0/2/2 got the config from int po21
when I then add gi 0/2/3 as channel-group 21 mode active, it doesnt receive the  int po21 trunk configuration
Is there a procedure to add an additional port to existing etherchannel
Chandru
manju.cisco
Level 3
Level 3
Hi Chandru,
Once Etherchannel is created and bundled with the  ports; any configuration applied to the etherchannel shall propagate to  the bundled ports; however any configuration applied to the physical  interfaces affects only that physical interface, it doesn't inherits the  configs from the etherchannel  when applied channel-group command
So, you have to manually configure the physical port w.r.t the configs of the etherchannel
If you shutdown the port-channel and un shut the port-channel the configurations will get synced.
However this requires down time.
Ideally for formation of port-channel all the interfaces should have identical configuration, and once the interfaces are mapped under the port-channel group all will be in down state.
Once the port-channel is up, then all the interfaces becomes up, and gets bundled to form a port-channel.
Hope this answers your question.
Cheers
Somu
Pls rate helpful posts
smogra
Either shut down the portchannel and do a no shut again.
Or try removing the configs and putting them again on port channel. When the configs will be put on the Port-Channel 21 interface, all  interface members of the channel-group will be removed from the group,  configuration will be applied then will be re-added to the channel-group.
But as Somu mentioned, please make sure that the new interface meets t\all the basic criterias to join the port channel.
Cheers
Sweta
