Bookmark
Subscribe
1918
Etherchannel Trunk and STP behavior
david
Hi all, have a quick question on etherchannel, trunking and spanning tree behavior.  In packet tracert I've setup 2 physical interfaces as etherchannel "po1" on each side of my switches.  I then configured po1 on each side to be a trunk.  This is working fine and if I shutdown a single port, the link stays active and I can still forward traffic.  Perfect so far!
However, when I do a "no shut" on the downed interface, the entire etherchannel goes through a Spanning Tree initialization and takes the entire etherchannel down for approximately 30 seconds.  Is this expected behavior?  I thought that Spanning Tree treated the Port Channel as a single entity and as long as one physical interface were up on each side, there would be no reason for spanning tree to renegotiate?
Edison Ortiz
When a port is added to a bundle, it needs to check for consistency.
Please read to this document for its behavior
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a008009448d.shtml
Hello
You are correct STP treats this as one instance, and the issue you have stated shouldn't really occur, can you post your L2 etherchannel config,
Also
sh spanning-tree interface port-channel x
sh etherchannel port-channel
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Edison, thanks for the link... will read in a few.
pdriver, keep in mind that I'm doing this in packet tracer for proof of concept before I try it in production so maybe it's a quirk with packet tracer?  Config is really bare bones  >
SW1
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 3
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 96
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 13
interface FastEthernet0/8
interface FastEthernet0/9
interface GigabitEthernet0/1
channel-group 1 mode on
switchport mode trunk
interface GigabitEthernet0/2
interface Port-channel 1
interface Vlan1
no ip address
shutdown
interface Vlan3
description 10.3.0.0
ip address 10.3.0.1 255.255.255.0
interface Vlan13
description 10.10.13.0
ip address 10.10.13.1 255.255.255.0
interface Vlan96
description 10.10.96.0
ip address 10.10.96.1 255.255.255.0
ip classless
SW2
interface Vlan1
no ip address
shutdown
ip classless
SW1
Switch#sh etherchannel port-channel
                Channel-group listing:
Group: 1
                Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 00d:14h:01m:55s
Logical slot/port   = 2/1       Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel
Protocol            =   PAGP
Port Security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gig0/2   On                 0
  0     00     Gig0/1   On                 0
Time since last port bundled:    00d:06h:29m:45s    Gig0/1
Switch#sh spanning-tree interface port-channel 1
no spanning tree info available for Port-channel1
Hello
Hum it seems you have created the port-channel first then confined the physical interfaces plus the interfaces looks like they are not are not active given the stp and ether-channel readouts
You say you need to aggregate physical port for server connection but at present the physical ports are trunked which indicates switch to switch connections -(would expect to see server porta in access mode)
Anyway please take a look at this post:
https://supportforums.cisco.com/message/4146391#4146391
Res
Paul
Kind Regards
Paul
