EtherChannel under Dynamic Routing Network
Tang-Suan Tan
Level 5
Level 5
Hi all :
I have configured the EtherChannel in a network. This is a Dynamic Network by using switches. The problem now I have is if between two switches with Dynamic Routing and there is EtherChannel for two ports (just a minimum 2 lines port-channel), the whole connection will down even I only shut up one port.
Below is configuration of two switches with the proper port-channel setup and these two switches are running OSPF routing, they are working fine with all the two ports are on. When anyone of the port is down, the whole connection is down. This is not good as the EtherChannel should provide redundancy that with one port down, another port should cover the connection and the connection should be normal.
By just taking out the  Dynamic Routing between these two switch, the two lines are acted as redundancy to cover each other.That means if I shut up one port, another port can act as connection for the two switches.
May I know is that a way by Dynamic Routing, the EtherChannel can work as redundancy?
Many thanks!
Best regards,
TangSuan Tan
Switch1 config :
Switch#sh run
Building configuration...
Current configuration : 1863 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
no ip domain-lookup
spanning-tree mode pvst!
interface FastEthernet0/1
no switchport
channel-group 1 mode on
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/2
no switchport
no ip address
duplex auto
speed auto
interface FastEthernet0/3
no switchport
channel-group 2 mode on
no ip address
duplex auto
speed auto
interface FastEthernet0/4
no switchport
no ip address
duplex auto
speed auto
interface FastEthernet0/5
no switchport
channel-group 3 mode on
no ip address
duplex auto
speed auto
interface FastEthernet0/6
no switchport
no ip address
duplex auto
speed auto
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Port-channel 1
no switchport
ip address 192.168.1.1 255.255.255.248
interface Port-channel 2
no switchport
ip address 192.168.4.1 255.255.255.248
interface Port-channel 3
interface Vlan1
no ip address
shutdown
router ospf 200
log-adjacency-changes
network 192.168.1.0 0.0.0.7 area 0
ip classless!
line con 0
exec-timeout 0 0
line vty 0 4
login
end
Switch#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/4/8 ms
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#int fa0/1
Switch(config-if)#sh
Switch(config-if)#
%LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
Switch(config-if)#end
Switch#
%SYS-5-CONFIG_I: Configured from console by console
Success rate is 0 percent (0/5)
Switch#
00:25:20: %OSPF-5-ADJCHG: Process 200, Nbr 192.168.1.2 on Port-channel 1 from FULL to DOWN, Neighbor Down: Dead timer expired
00:25:20: %OSPF-5-ADJCHG: Process 200, Nbr 192.168.1.2 on Port-channel 1 from FULL to DOWN, Neighbor Down: Interface down or detached
Switch 2 config :
Switch#sh run
Current configuration : 1445 bytes
version 12.2
hostname Switch
no ip domain-lookup
no switchport
no ip address
duplex auto
speed auto
no switchport
no ip address
duplex auto
speed auto
no switchport
ip address 192.168.1.2 255.255.255.248
interface Vlan1
no ip address
shutdown
router ospf 200
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
login
end
Switch#
Reza Sharifi
Can you change the mode to active on one side and passive on the other side and test again?
switch-2
no switchport
channel-group 1 mode active
no ip address
duplex auto
speed auto
switch-1
no switchport
channel-group 1 mode passive
no ip address
duplex auto
speed auto
shutdown
