etherchannel
sarahr202
Level 5
Level 5
Hi every body!
Let say we have a etherchannel named port-channel p01.
Po1 has three ports in access mode.
My question is is it possible to configure po1 as trunk which in turn set the components ports in etherchannel as trunk?
thanks a lot!
Roberto Salazar
Level 8
Level 8
short answer is yes.
Here is what it looks like in an actual switch:
interface Port-channel50
switchport
switchport mode access
load-interval 30
end
c6509#sh int port 50
Port-channel50 is up, line protocol is up (connected)
Hardware is EtherChannel, address is
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is on
Members in this channel: Gi4/45 Gi4/46
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
14591 packets input, 2170794 bytes, 0 no buffer
Received 14591 broadcasts (14579 multicasts)
0 watchdog, 0 multicast, 0 pause input
c6509#sh etherc sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
50 Po50(SU) PAgP Gi4/45(P) Gi4/46(P)
c6509#conf t
Enter configuration commands, one per line. End with CNTL/Z.
c6509(config)#int port 50
c6509(config-if)#switch mode trunk
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
c6509-E(config-if)#switch trunk encap dot1q
c6509-E(config-if)#switch mode trunk
c6509-E(config-if)#end
c6509-E#
*Jan 9 04:14:53.197: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/45, changed state to down
*Jan 9 04:14:53.205: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/46, changed state to down
*Jan 9 04:14:53.205: %EC-SP-5-UNBUNDLE: Interface GigabitEthernet4/45 left the port-channel Port-channel50
*Jan 9 04:14:53.213: %EC-SP-5-UNBUNDLE: Interface GigabitEthernet4/46 left the port-channel Port-channel50
*Jan 9 04:14:54.701: %SYS-5-CONFIG_I: Configured from console by console
*Jan 9 04:14:56.704: %DTP-SP-5-TRUNKPORTON: Port Gi4/45-Gi4/46 has become dot1q trunk
*Jan 9 04:14:58.937: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/45, changed state to up
*Jan 9 04:14:59.073: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4/46, changed state to up
*Jan 9 04:14:58.907: %EC-SP-5-BUNDLE: Interface GigabitEthernet4/45 joined port-channel Port-channel50
*Jan 9 04:14:59.058: %EC-SP-5-BUNDLE: Interface GigabitEthernet4/46 joined port-channel Port-channel50
c6509-E#
c6509-E#sh int trunk
Port Mode Encapsulation Status Native vlan
Po50 on 802.1q trunking 1
Port Vlans allowed on trunk
Po50 1-4094
Port Vlans allowed and active in management domain
Po50 1,10,55-57,200,601-605,999
Port Vlans in spanning tree forwarding state and not pruned
Po50 none
c6509-E#
4/45 and 4/46 were initially both access ports as you can see the port-channel 50 that resulted in putting both 4/45 and 4/46 to channel-group 50. Upon making the port-channel 50 a trunk channel the physical interfaces also became trunks.
This answers your question.
10 Replies 10
Jerry Ye
Hi Sarah,
All ports in an etherchannel needs to have identical configuration.
HTH,
jerry
Roberto Salazar
Level 8
Level 8
switchport
load-interval 30
end
c6509#sh etherc sum
d - default port
c6509#conf t
c6509-E#
c6509-E#
Po50 1-4094
Po50 none
c6509-E#
Thanks a lot Bosalaza !
I really appreciate your help.
Hi, I've been tasked with implementing VLAN pruning and ran across this. Will this same scnerio work if - once I enable pruning on the server switch if I could manually enable pruning on the port-channels and let it propagate to the low end devices? I seen that adding the trunk in the ether-channel did work, this seems like the same type of thing? Thanks,
Ted
You don't need to enable VTP pruning on the individual port channels. Just enable VTP pruning on the VTP server in global configuration mode and this will then propogate to all your client switches.
Jon
I have devices with max stp instance currently on them and can not add another vlan to them with our a core melt down. I understand that I need to add VTP pruning on the VTP server. But on my low end switches is where I want to free up STP instances. I need to manually do this. These low end blade switches connect to my core via port-channel and they are trunks as well. Thanks, Ted
Ted
If you are trying to free up STP instances then don't use VTP pruning. Instead use the "switchport trunk vlan allowed ....." command. If you don't allow a vlan on a trunk link then an instance of STP does not run across it.
With VTP pruning it still runs an STP instance.
Jon
Ok, I was misinformed then, I thought manual creation of vtp pruning would free up stp instances - only the aut0matic enabling of vtp pruning kept the intstances. Ok so will adding the switchport trunk allowed vlan #'s to the port-channel work? Also I do still need to delete some of the VLAN's allowed still. If you know of a good document plese send it my way. Thanks for your help.
Ted
Sincere apologies, but you may well be right actually. What you have just said rings a bell. I was assuming you were looking to do automatic VTP pruning but that was my misunderstanding.
In fact i have just found one of my old posts confirming that if you use the "switchport trunk pruning" command at the interface level.
So yes you should be able to add this to this to the individual interfaces on your port-channel and it should works as you intend.
Jon
Ok super because I need to fix this issue in a timely manner and have a lot of low end switches with a number of trunks connected. By being able to add this to the port-channel will help with the some of the actual ports i need to touch. Would you happen to know the best method for deleting unused VLANs on some of these trunks that are set to be pruned? Thanks again, Ted
