Cisco Catalyst 3560G-24TS Question
tariqmansoor
HI Team,
Can you please confirm if "Cisco Catalyst 3560G-24TS" is a layer 3 switch or layer 2 switch.
After upgrading the IOS to advanced IP services i still could not see any options in Cisco DM to configure IPs on each port or IP on each VLAN.
Thansk Team
Yes it does intervlan routing , with ip base its static and RIP and eigrp stub i believe . With enterprise it will support all major routing protocols bgp,ospf,eigrp etc... Wish I could help you with the gui but not too many people use it in this forum . Most of us are CLI geeks :-)
5 Replies 5
Mark Yeates
Level 7
Level 7
The 3560 is a layer 3 switch. Not familiar with the Cisco DM, but those can be configured by the CLI.
interface vlan 1
ip address 10.1.1.1 255.255.255.0
interface vlan 2
ip address 10.2.1.1 255.255.255.0
ETC....
HTH,
Mark
Thanks, Can this also perform intervlan routing using its own routing table ?
We can not see this funsctionality in Cisco DM gui, Can we not achive this through the use of GUI ?
Thanks, That resolved the issue
Yes the switch is capable of doing inter-VLAN routing and run routing protocols. I have not used the GUI for the switch, so I am not familiar with it's capabilities. Here is a CLI configuration guide. I will try to see if there is one available for the GUI.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_40_se/configuration/guide/swcli.html
