Etherchannel
pccthailand
Level 3
Level 3
Can I setup Etherchannel between Fastethernet port and Gigabit port together ?
mahmoodmkl
Level 11
Level 11
No u cannot setuo etherchannel between fastethernet and gigbit ethernet as etherchannel requires same speed ports,same duplex,same vlan info.
Mahmood
pccthailand
Level 3
Level 3
If i fix speed (100 Mbps) and duplex (full) on gigabit port as same as fastethernet port , can i build etherchannel ?
Didnt tried this but i think should work.Its worth giving a shot as long as the settings are same on both the sides.
Mahmood
There is no possibilty for doing FE/GE ether channel , so try for seperate ether channel
