05-28-2008 01:14 PM - edited 03-05-2019 11:17 PM
hi everybody!
I was reading bcmsn guide, and got stuck with one thing.
If we have two swithes sw1 and sw2.
sw1 and sw2 are connected by f0/1,and f0/2 on both sides.
Ether channel will form or not if sw1 has f0/1 and f0/2 in vlan 2 while sw2 has f0/1 and f0/2 in vlan 3?
thanks alot!
Solved! Go to Solution.
05-28-2008 01:42 PM
I had to test this myself as I wasn't 100% sure.
Surprisingly, the etherchannel does form.
Switch 3 Config
S3(config)#int ran f0/13-14
S3(config-if-range)#switchport access vlan 4
S3(config-if-range)#channel-group 1 mode desirable
Creating a port-channel interface Port-channel 1
Switch 1 Config
S1(config)#int r f0/16-17
S1(config-if-range)#switchport access vlan 21
S1(config-if-range)#channel-group 1 mode desirable
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to down
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to up
Switch 1 Etherchannel Summary Output
1w2d: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
S1(config-if-range)#do show ether sum
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Fa0/16(P) Fa0/17(P)
Switch 3 Etherchannel Summary Output
S3(config-if-range)#do show ether sum
d - default port
1 Po1(SU) PAgP Fa0/13(P) Fa0/14(P)
HTH,
__
Edison.
Please rate helpful posts
05-28-2008 01:42 PM
Switch 3 Config
Switch 1 Config
d - default port
d - default port
HTH,
__
Edison.
05-28-2008 02:00 PM
This is weird Edison....have you waited a few minutes to see if channels goes down.
While doing some labs a few months ago I recall (not sure what kind of lab though) etherchannel went up for few minutes and then down!
05-28-2008 02:11 PM
Still up, 30 minutes later.
05-28-2008 02:16 PM
This is interesting that the etherchannel would successfully come up. I guess that PAGP must not check that the vlans are the same. Curious if the channel would come up using LACP instead (probably since this one came up).
Of course, a person studying this should realize that while this may come up - that this isn't the right way to do things and that you probably don't have any connectivity across it. Definitely don't want to see this in a production network 🙂
05-28-2008 02:20 PM
This would probably work fine on a strict access mode connection as it doesn't care about anything other than the connection across it (layer 2 ) . If you add trunking to the ehterchannel and use channel negotiation I know it will not come up and will tell you so if stuff like native vlans and such do not match.
05-28-2008 03:30 PM
how about if native vlans are same?will it
come up?
05-28-2008 03:44 PM
In this case, it will be a trunking mismatch issue, not really an etherchanneling issue.
05-28-2008 06:25 PM
Technically that is true but it still keeps the port channel from coming up when this happens also.
05-28-2008 06:48 PM
Well, let's see....
Switch 3
Port Mode Encapsulation Status Native vlan
Fa0/13 on 802.1q trunking 4
Fa0/14 on 802.1q trunking 4
S3#sh run int f0/13
interface FastEthernet0/13
switchport trunk native vlan 4
switchport mode trunk
S3#sh run int f0/14
interface FastEthernet0/14
Switch 1
S1#sh int trunk
Fa0/16 on 802.1q trunking 21
Fa0/17 on 802.1q trunking 21
sh run int f0/16
interface FastEthernet0/16
switchport trunk native vlan 21
S1#sh run int f0/17
interface FastEthernet0/17
end
Now, let's do some etherchanneling, shall we?
S3(config-if-range)#channel-group 1 mode active
04:56:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/13, changed state to down
04:56:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/14, changed state to down
S1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
S1(config)#int rang f0/16-17
04:56:52: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/16 on VLAN0021. Port consistency restored.
04:56:52: %SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/17 on VLAN0021. Port consistency restored.
S1(config-if-range)#channel-group 1 mode active
S1(config-if-range)#end
S1#
04:56:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to down
04:56:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to down
04:56:59: %SYS-5-CONFIG_I: Configured from console by console
04:57:00: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
04:57:01: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 4 on Port-channel1 VLAN21.
04:57:01: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking Port-channel1 on VLAN0021. Inconsistent local vlan.
04:57:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/16, changed state to up
04:57:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
04:57:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to up
S1#
S1#show ether sum
d - default port
1 Po1(SU) LACP Fa0/16(P) Fa0/17(P)
S1#
S3#sh e
04:58:26: %SYS-5-CONFIG_I: Configured from console by consolether sum
d - default port
1 Po1(SU) LACP Fa0/13(P) Fa0/14(P)
05-29-2008 03:19 AM
Ok I knew there was an issue , so basically neither vlan 21 nor vlan 4 is going to transfer data across the link due to spanning tree isuues with misconfiguration . This is also one of my arguments to let the link negotiate instead of hardcoding the trunks and etherchannels but I know this would create a whole line of opinions why you should or should not hardcode trunks and etherchannels.
05-29-2008 07:43 AM
So the bottom line is etherchannel does come up though trunk port have different native vlan. It also contradicts what the author david hucaby says in his book "Bcmsn guide"
" native vlans must be same on either end of trunks for the formtion of etherchannel"
thanks to everyone who responded to my post.
05-29-2008 10:49 PM
I wonder if this is another case where the message got garbled on its way from the mind to the writer to his keyboard. Is it possible he meant to say "native vlans must be the same on each of the trunk links for the formation of etherchannel."?
It is interesting that it forms an etherchannel even with mismatched native vlans on each end. Glan is right about this being a good argument for negotiating EtherChannels rather than hard coding them.
Kevin Dorrell
Luxembourg
