etherchannels
Patrick McHenry
Level 4
Level 4
I put this question in a discussion a few days ago and it wasn't answered completey so, I'll try to ask again. Check out the diagram.
I was wondering if and etherchannel can be created by using one link that uses single mode fiber and one that uses multimode fiber? We currently have a 10G link between our core switches using single mode fiber. The link that I want to bundle it with has to be multimode because of the interfaces that we have left on both cores. I know you can create etherchannels with fiber and copper links together but, can you do it with single mode and multimode fiber links?
Thanks, Pat.
IAN WHITMORE
Level 4
Level 4
Hi. In theory I think you can as the conditions for etherchannel state that the ports have to be the same speed...which in this case they are - both 10g. However I haven't had the opportunity to try this myself.
Can you not try it? I suppose we are talking about a production network?
You might like to check this document out:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_white_paper09186a0080092944.shtml
Ian
Thanks.
Some good info but, the doc didn't really make me feel that it was compatible for sure.
