Ethernet card
ericdegboevi
Level 2
Level 2
Hi all,
I need an ethernet card with 2 ports
we have the card with 1 port WIC-1ENET=
If there is a card with 2 port let me have the part number
Note: I do not need a switchport. I neet ethernet port.
Eric
If i understand you need a routed ethernt port.
For 2811 you can use the 1-port HWIC-1FE
2 port is not supported on the 2811
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008068dde6.html#wp1049748
For 2611 check this link
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b89.html
HTH, rate if it does
Narayan
royalblues
Level 11
Level 11
which platform are you looking this for?
i need it for 2611 or 2811 series router
Thaks
Narayan
