6506 EtherChannel
j.lipsett
Level 3
Level 3
I have two Cat 6506 with 2 1000Basex Gbic blades each in slots 2 & 3. Can you form an Etherchannel group with ports on different blades i.e. ports 2/16 & 3/16?
Running CatOS 8.3(3).
2 Accepted Solutions
Hi John
Yes that is the right command for CatOS.
Jon
As Jon said the commands are correct.
Mahmood
mahmoodmkl
Level 11
Level 11
As long as the ports are of same type u can form the ether-channel with ports on different blades within the same chassis.
Mahmood
Mahmood
Thank for that. the config would be -
set port channel 2/16 3/16 on? (Both switches).
Regards John
Hi John
Jon
Mahmood
