Ethernet OAM CFM
v_pravdin
I was configured CFM between c4948 and mx80.
(mx80#1-mep<---->mip-c4948#1-mip<--->mip-c4948#2-mip<---->mx80#2-mep)
Then i do traceroute ethernet from mx80#1 to mx80#2, some times i cann't seen MAC address of cisco-switch.
What is it mean?
I use IOS 15.0(2)SG
Some configuration:
ethernet cfm ieee
ethernet cfm global
ethernet cfm traceroute cache
ethernet cfm mip auto-create level 5 vlan 1-4094 sender-id chassis
ethernet cfm domain J-sw-J level 5
id dns J-sw-J
sender-id chassis
mip auto-create
service J-sw-J vlan 1 direction down
ethernet cfm logging
interface GigabitEthernet1/1
ethernet cfm mip level 5 vlan 1-4094
interface GigabitEthernet1/2
Some command  output:
Switch#show ethernet cfm maintenance-points remote
Switch#
sh ethernet cfm mpdb
* = Can Ping/Traceroute to MEP
MPID  Domain Name                                 MacAddress          Version
Lvl   Domain ID                                   Ingress
Expd  MA Name                                     Type Id             SrvcInst
EVC Name                                                        Age
15    J-sw-J                                      5c5e.ab08.0080      IEEE-CFM
5     J-sw-J                                      Gi1/2
-     J-sw-J                                      Vlan 1              N/A
N/A                                                             0s
22    J-sw-J                                      8071.1fc3.f180      IEEE-CFM
5     J-sw-J                                      Gi1/1
-     J-sw-J                                      Vlan 1              N/A
N/A                                                             0s
Total Remote MEPs: 2
sh ethernet cfm maintenance-points local detail
Local MEPs:
MIP Settings:
Local MIPs:
* = MIP Manually Configured
Level Port           MacAddress     SrvcInst   Type    Id
*5     Gi1/1          c89c.1def.053d N/A        Vlan    1-4094
*5     Gi1/2          c89c.1def.053d N/A        Vlan    1-4094
5     Gi1/3          c89c.1def.053d N/A        Vlan    1
5     Gi1/4          c89c.1def.053d N/A        Vlan    1
5     Gi1/5          c89c.1def.053d N/A        Vlan    1
5     Gi1/6          c89c.1def.053d N/A        Vlan    1
5     Gi1/7          c89c.1def.053d N/A        Vlan    1
5     Gi1/8          c89c.1def.053d N/A        Vlan    1
5     Gi1/9          c89c.1def.053d N/A        Vlan    1
5     Gi1/10         c89c.1def.053d N/A        Vlan    1
5     Gi1/11         c89c.1def.053d N/A        Vlan    1
5     Gi1/12         c89c.1def.053d N/A        Vlan    1
5     Gi1/13         c89c.1def.053d N/A        Vlan    1
5     Gi1/14         c89c.1def.053d N/A        Vlan    1
5     Gi1/15         c89c.1def.053d N/A        Vlan    1
5     Gi1/16         c89c.1def.053d N/A        Vlan    1
5     Gi1/17         c89c.1def.053d N/A        Vlan    1
5     Gi1/18         c89c.1def.053d N/A        Vlan    1
5     Gi1/19         c89c.1def.053d N/A        Vlan    1
5     Gi1/20         c89c.1def.053d N/A        Vlan    1
5     Gi1/21         c89c.1def.053d N/A        Vlan    1
5     Gi1/22         c89c.1def.053d N/A        Vlan    1
5     Gi1/23         c89c.1def.053d N/A        Vlan    1
5     Gi1/24         c89c.1def.053d N/A        Vlan    1
5     Gi1/25         c89c.1def.053d N/A        Vlan    1
5     Gi1/26         c89c.1def.053d N/A        Vlan    1
5     Gi1/27         c89c.1def.053d N/A        Vlan    1
5     Gi1/28         c89c.1def.053d N/A        Vlan    1
5     Gi1/29         c89c.1def.053d N/A        Vlan    1
5     Gi1/30         c89c.1def.053d N/A        Vlan    1
5     Gi1/31         c89c.1def.053d N/A        Vlan    1
5     Gi1/32         c89c.1def.053d N/A        Vlan    1
5     Gi1/33         c89c.1def.053d N/A        Vlan    1
5     Gi1/34         c89c.1def.053d N/A        Vlan    1
5     Gi1/35         c89c.1def.053d N/A        Vlan    1
5     Gi1/36         c89c.1def.053d N/A        Vlan    1
5     Gi1/37         c89c.1def.053d N/A        Vlan    1
5     Gi1/38         c89c.1def.053d N/A        Vlan    1
5     Gi1/39         c89c.1def.053d N/A        Vlan    1
5     Gi1/40         c89c.1def.053d N/A        Vlan    1
5     Gi1/41         c89c.1def.053d N/A        Vlan    1
5     Gi1/42         c89c.1def.053d N/A        Vlan    1
5     Gi1/43         c89c.1def.053d N/A        Vlan    1
5     Gi1/44         c89c.1def.053d N/A        Vlan    1
5     Gi1/45         c89c.1def.053d N/A        Vlan    1
5     Gi1/46         c89c.1def.053d N/A        Vlan    1
5     Gi1/47         c89c.1def.053d N/A        Vlan    1
5     Gi1/48         c89c.1def.053d N/A        Vlan    1
5     Te1/49         c89c.1def.053d N/A        Vlan    1
5     Te1/50         c89c.1def.053d N/A        Vlan    1
5     Te1/51         c89c.1def.053d N/A        Vlan    1
5     Te1/52         c89c.1def.053d N/A        Vlan    1
Total Local MIPs: 8238
Traceroute from Juniper output:
traceroute ethernet 5c:5e:ab:08:00:80 mep 15 maintenance-domain J-sw-J maintenance-association J-sw-J ttl 5 wait 2
Linktrace to 5c:5e:ab:08:00:80, Interface : ge-1/1/8.0
Maintenance Domain: J-sw-J, Level: 5
Maintenance Association: J-sw-J, Local Mep: 22
Transaction Identifier: 52
Hop   TTL    Source MAC address        Next-hop MAC address
1     2      5c:5e:ab:08:00:80         00:00:00:00:00:00 << ONLY LAST HOP >>
Transaction Identifier: 53
1     4      c8:9c:1d:ef:05:3d         c8:9c:1d:ef:05:3d
2     3      c8:9c:1d:ef:38:7d         c8:9c:1d:ef:38:7d
3     2      5c:5e:ab:08:00:80         00:00:00:00:00:00
0 Replies 0
