Extended ACL for ICMP blocking DHCP requests
bstevenson11
Greetings,
I setup the network in the image attached with Netsim 11. I am having issues with Extended access lists. At the moment I have the current config on Router4. For some reason once I enabled that on int fa0/1.100 as an inbound access list dhcp requests are not being received on the pc's connected to Switch2. If I turn off the access list they function fine and receive DHCP info. Can you tell me what I am doing wrong? My goal was to block pings by denying ICMP packets heading to the 10.0.0.64 0.0.0.63 network from the source 192.168.0.34. That worked great, but then DHCP stopped working.
hostname Router4
ip subnet-zero
ip cef
no ip domain-lookup
ip domain-name boson.com
interface Ethernet0/0
ip address 192.168.0.2 255.255.255.240
no ip directed-broadcast
interface Ethernet0/1
no ip address
interface Ethernet0/1.100
encapsulation dot1q 100
ip address 192.168.0.33 255.255.255.240
ip helper-address 192.168.0.1
ip access-group 101 in
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
router eigrp router4
ip classless
no ip http server
ip route 10.0.0.64 255.255.255.192 Ethernet0/0
ip route 10.0.0.0 255.255.255.192 Ethernet0/0
access-list 101 deny icmp host 192.168.0.34 10.0.0.64 0.0.0.63
access-list 101 permit icmp any any
access-list 101 permit udp any any
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
Mark Malone
Theres an implicit deny at then end of every acl by default , you should have below too
access-list 101 permit ip any any
