Can't reach subinterfaces through ping
bstevenson11
Hi There,
I am using Boson Netsim to create this simulated environment.My configuration is below. I have also included an image for a visual. I am unable to copy and paste for some reason, so I apologize for the lack of information.
My issue is I am unable to ping the ip address on both subinterfaces on Router3 and Router4. I can ping et0/0 on Router4 but not Et0/1.100 on Router4. Same goes for Router3.
I have setup the default gateway on the switch and the ip helper-address on the subinterface, but have no luck. Please let me know what I am missing here, it is driving me crazy.
Router 1:
Fa0/0 - (connected to Router4 Et0/0)
ip address 192.168.0.1 255.255.255.240
ip route 192.168.0.32 255.255.255.240 192.168.0.2 (router4)
ip route 10.0.0.64 255.255.255.192 10.0.0.3 (router3)
Fa0/1 (connected to Router3 Fa0/0)
ip address 10.0.0.1 255.255.255.192
Router 4:
Et0/0 - 192.168.0.2 255.255.255.240
encapsulation dot1q 100
Et0/1.100 - 192.168.0.33 255.255.255.240
Ip helper-address 192.168.0.1
Switch 2:
Int fa0/1 (connected to Et0/1.100) -
Switchport mode trunk
switchport access vlan 100
int fa0/2 (connected to PC) -
Switchport mode access
Int fa0/3 (connected to pc)-
ip default-gateway 192.168.0.33
Router3:
int fa0/0 - Ip address 10.0.0.3 255.255.255.192
int fa0/1.200 - ip address 10.0.0.65 255.255.255.192
encapsulation dot1q 200
ip helper-address 10.0.0.1
IP route 192.168.0.0 255.255.255.240 10.0.0.1
Switch1:
Int fa0/1 -(Connected to PC)
switchport access vlan 200
Int fa0/2- (connected to Router3)
switchport trunk allowed vlan 200
IP default-gateway 10.0.0.65
5 Replies 5
cofee
Level 5
Level 5
This appears to be a duplicate thread. You never followed through the other discussion thread that you created few days ago.
https://supportforums.cisco.com/discussion/13352286/help-pinging-host-router-through-vlan
Thanks for replying.
This isn't a duplicate threat. That thread was solved with a DG being added to the users computer. With this issue I am unable to communicate from PC4 for example, to Router4's fa0/0 or fa0/1. I am also unable to ping Router4 Eth0/1 from Router3. I can ping Eth0/0 just fine, but not Ether0/1.
If you look at the Diagram Router1 can communicate full with everything. Just communication between Router4 and subinterface on Router3 and vice versa is not working. Router 4 can communication with Router3 fa0/0 just not Router3 fa0/1.200. Same goes for Router3. Router3 can communicate with Rotuer4 eth0/0, but not eth0/1.100.
I have made some changes to configuration, try it and let me know the results.
Make sure the end hosts are using following gateways:
vlan 100
default gateway - 192.168.0.33
vlan 200
default gateway -
10.0.0.65
Router 1:
int Fa0/0
no shut
int Fa0/1
no shut
Router 4:
int Et0/0
no shut
int eth0/1
no shut
int Et0/1.100
Switch 2:
Int fa0/1
switchport mode trunk
switchport encapsulation dot1q
no shut
int fa0/2
no shut
Int fa0/3
no shut
Router3:
int fa0/0 -
ip address 10.0.0.3 255.255.255.192
no shut
int f0/1
no shut
int fa0/1.200
IP route 192.168.0.0 255.255.0.0 10.0.0.1
Switch1:
Int fa0/1
Int fa0/2
no shut
I found it was a flaw in the Boson Netsim 11 simulator. static routes by IP are not working at the moment, so I switched to using interfaces or EIGRP and everything worked. They are currently working on a fix. Caused me a bunch of headaches though lol
Thanks!
Good to know that you found the issue. Thanks for the update!
