Factory default c9600 via rommon mode
dijix1990
After enable SVL mode one of my C9600 stuck into RPR Mode: Remote supervisor is already active
I tried to insert command
SWITCH_IGNORE_STARTUP_CFG=1
but it did't help
rommon 1 >SWITCH_IGNORE_STARTUP_CFG=1
rommon 2 >boot
Preparing to autoboot. [Press Ctrl-C to interrupt]  0
boot: attempting to boot from [bootflash:packages.conf]
boot: reading file packages.conf
Waiting for remote chassis to join
                 Chassis number is 2
              Restricted Rights Legend
and after reloading it stucks again
of course it the same c9606, same software, same supervisors, I managed to stop to reload switch only after unset config SVL via rommon...
rommon 1 > unset D_STACK_DAD
rommon 1 > unset D_STACK_DISTR_STACK_LINK1
rommon 1 > unset D_STACK_DISTR_STACK_LINK2
rommon 1 > unset D_STACK_DOMAIN_NUM
rommon 1 > unset D_STACK_MODE
rommon 1 >SWITCH_NUMBER=1
rommon 1 > boot
8 Replies 8
dijix1990
before it I removed secondary supervisor
balaji.bandi
why are you ignoring Startup config ?
after booting the device can you share
#show boot
#show version
BB
can't because after configuring SVL i getting
*Aug 25 11:16:29.495: %PMAN-5-EXITACTION: Chassis 2 F0/0: pvp: Process manager is exiting: Critical process fed fault on fp_0_0 (rc=139)
*Aug 25 11:16:29.800: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 F0/0: rdope.sh: Error resolving local FRU: Invalid argument
*Aug 25 11:16:29.802: %SERVICES-3-INVALID_CHASFS: Chassis 2 F0/0: rdope.sh: Thread 0x7fc29b4309c0 has no global chasfs context
*Aug 25 11:16:30.040: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C4/0: btman: Error resolving local FRU: Invalid argument
*Aug 25 11:16:30.040: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C5/0: btman: Error resolving local FRU: Invalid argument
*Aug 25 11:16:30.041: %SERVICES-3-INVALID_CHASFS: Chassis 2 C5/0: btman: Thread 0x7f8d60da79c0 has no global chasfs context
*Aug 25 11:16:30.041: %SERVICES-3-INVALID_CHASFS: Chassis 2 C4/0: btman: Thread 0x7f61d82e99c0 has no global chasfs context
*Aug 25 11:16:30.048: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C6/0: btman: Error resolving local FRU: Invalid argument
*Aug 25 11:16:30.050: %SERVICES-3-INVALID_CHASFS: Chassis 2 C6/0: btman: Thread 0x7fb7c61109c0 has no global chasfs context
*Aug 25 11:16:30.084: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C2/0: btman: Error resolving local FRU: Invalid argument
*Aug 25 11:16:30.084: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C1/0: btman: Error resolving local FRU: Invalid argument
*Aug 25 11:16:30.084: %SERVICES-2-NORESOLVE_LOCAL: Chassis 2 C3/0: btman: Error resolving local FRU: Invalid argument
Chassis 2 reloading, reason - Reload command
Aug 25 11:16:40.930: %PMAN-5-EXITACTION: R0/0: pvp: ger is exiting: reload fru action requested
 version 17.09.03
i am trying to understand the problem - is this issue when you building the SVL ? working SVL Failing
i am sure you followed SVL requirement -
hardware should be same
save IOS code
same License code.
as i asked what version of code and model having this issue ?
There are some bugs around the messages :
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvt22293
BB
rommon 1 > boot
17.9.3 , with advantage licence
glad all good and thank you sharing the solution.
BB
dijix1990
Every time reload after
