Failed dynamic routing, route distribution
baba_yaga
I have superlab
1. VLAN
2. TRUNK
3. INTERVLAN ROUTING
4. DHCP
5. OSPF
6. FRAME RELAY
7. BGP
8. ETHERCHANNEL
9. ROUTE REDISTRIBUTION
with topology like this belowSuperlab 9Superlab 9Until NXT-Core-Network & NXT-R1 I can ping but after that device I can't ping & access what I miss for configuration? So I can ping or access every server
The pkt file is in the link below
https://drive.google.com/open?id=1QJwTDkvzYoC4DoVOm2A3MkCHZ5-mhAFD
Please run following commands on both switches (Keep in mind the Port numbers)
NXT-CORE-NETWORK(config)#interface range gigabitEthernet 1/0/7-8
NXT-CORE-NETWORK(config-if-range)#no switchport
NXT-CORE-NETWORK(config-if-range)#channel-group 4 mode active
NXT-CORE-NETWORK#
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
15 Replies 15
I was unable to open the PT file, What version are you using?  Could you please provide more details?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I use Packet Tracer version 7.1.0.0222. do you want the link download for that PT?
From above topology I success config for DHCP, trunk, Etherchannel & intervlan routing but I think for OSPF, Frame Relay, BGP & Route Distribution config is failed that show from PT file(from Laptop to Multi layer switch NXT-Core-DC & router R1 serial 0/0/0 ) I can't ping data center server & ISP Network server.
Up
baba_yaga
Up
on router NXT-R1 you need to redistribute BGP into OSPF:
NXT-R1(config-router)#redistribute bgp 100 subnets
Deepak Kumar
I want to share some information with you.
There is no default route information added in OSPF from the router "NXT-R1" because this is a border router between our local LAN and ISP.
Your OSPF configuration must be as below on NXT-R1 router.
router ospf 1
log-adjacency-changes
network 192.168.1.0 0.0.0.255 area 0
default-information originate
Why no redistribution between OSPF and BGP?
This is a border router between LAN and WAN network so in the real world it is not possible to router local subnet on the WAN network and second think NAT is already placed on router in the correct way. So we need to troubleshoot the routing issue.
Deepak Kumar
From Mobile>>>
Deepak Kumar,
Thanks for your solution & your suggestion now the laptop/PC can access the ISP network server.
And for data center multilayer switch NXT-CORE-DC still can't access, what configuration I missed
Port channel between "NXT-CORE-DC" and "NXT-CORE-NETWORK" is not configured properly. You have to reconfigure the port channel.
Deepak Kumar
Deepak Kumar,
I already attempt to fix configuration port channel but still port channel 4 status down & protocol down for port channel 4
Port-channel4 unassigned YES unset down down
Etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 4
Number of aggregators: 4
Group Port-channel Protocol Ports
4 Po4(RD) LACP Gig1/0/7(I) Gig1/0/8(I)
NXT-CORE-NETWORK#
Deepak Kumar
Deepak Kumar,
Ok thanks a lot
vyasr2010
Just configure redistribution  on NXT-R1 for ospf and bgp.
Refer below configuration.
router ospf 1
exit
router bgp 100
redistribute ospf 1
exit
@vyasr2010 Dont mind:
is it possible to redistribution from Local IP address (LAN) to wan IPs in the real world? I hope you didn't check the lab. The router name, where is it installed, and what is his task? all are mentioned clearly.
Deepak Kumar
Deepak Kumar,
Hi Deepak,
It is possible to redistribution from Local IP address (LAN) to wan IPs in the real world.
router ospf 1
exit
router bgp 100
redistribute ospf 1
exit
 Refer below snap.
