Failover problem in 6509 switches
sunil-koul
We have connected 2 sql servers (one to primary switch 6509 and one to secondary switch 6509).Once we are doing failover of secondary switch just disabling port of secondary switch where Sql server is connected.It fails but if both servers are connected to 2 different ports on same switch (primary switch) it works.Can anyone guide what may be the problem here.
Sandeep Choudhary
HI Sunil,
Have you done with these steps??
1) Connect the 2 switches with a Layer 2 etherchannel trunk
2) Create your server vlans on the switches
3) Create the L3 interfaces for your vlans and use HSRP to have a virtual IP.
4) Set the default gateway of the servers to be the virtual IP of their relevant vlan.
5) Dual connect your router to both switches
or
Or if the switch have 2 diff ip address then....use this example
Switch1:
interface Port-channel29
description *** Po29, 2 CU Etherchannel 9/15-9/16, Server Name ***
switchport
switchport access vlan 10
switchport mode access
no ip address
Switch 2:
description *** Po29, 2 Port CU Etherchannel 10/9-10/10 Server name ***
switchport
no ip address
Port config:
Intrface GigabitEthernet9/16
description *** Gi9/15, Server name***
switchport
no ip address
speed 1000
duplex full
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
channel-group 29 mode active
interface GigabitEthernet9/16
description *** Gi9/16, Server name ***
switchport
no ip address
speed 1000
duplex full
no cdp enable
Please rate if it helps.
