Failover with "rtr" command
aparikh
I have 6513 - s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF17a
I want to do failover to the backup ISP with the "rtr" command (btw - ip sla command isnot available).
I can configure
rtr 2
type echo protocol ipIcmpEcho 4.2.2.2
rtr schedule 2 life forever start-time now
but - ip route 0.0.0.0 0.0.0.0 x.x.x.x track 1 (MISSING).
can someone show me the complet  failover configuraiton with "rtr" command ?
srikanth ath
Level 4
Level 4
Try this
rtr 1
type echo protocol ipicmpecho x.x.x.x ---> Configures an SAA end-to-end echo response time probe operation.
rtr schedule 1 life forever start-time now  --> Configures the time parameters for the SAA operation.
track 123 rtr 1 reachability--> Configures the time parameters for the SAA operation.
  delay up 60 down 30 --->  Specifies a period of time (in seconds) to delay communicating state changes of a tracked object.
ip route 0.0.0.0 0.0.0.0 x.x.x.x track 123
USe this link:http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_pi/configuration/12-4t/iri-pbr-mult-track.html
Let us know if you require anything more.
srikanth
***  PLease rate helpfull posts ***
Following two commands are not available in the 6513 IOS -  Version 12.2(18)SXF17a
Hmm.. without the track command you cannot achieve the failover with IP-sla.
srikanth
Please rate the helpful posts.
