2921 interface not coming up
Kashish_Patel
Level 2
Level 2
I have a CISCO2921. I am not able to bring up its gi0/1 interface. It stays down down.
From http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/backup.html#wpxref16106, it looks like its gi0/1 interface is different from its gi0/0 or gi0/2 interfaces.
I know that interface is not coming up because of "no media" below.
Router#sh int gi0/1 | i media
  Auto Duplex, Auto Speed, media type is no media
I have tried media rj-45 and media sfp which have also not worked.
The other end of this link is ethernet handoff. What is it that I have to do for the link to come up? If I change the connection to gi0/2, I think that will work because I see this for gi0/2:
Router#sh int gi0/2 | i media
  Auto Duplex, Auto Speed, media type is RJ45
But why is it not working for gi0/1?
10 Replies 10
Raju Sekharan
Did you try moving the link to gig0/1?
Get the following outputs
1. Show inv
2. show diag
3. show int gi 0/1
4. show int gi 0/2
Yes the link is patched to gi0/1 currently and is not coming up.
Router#sh inventory
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V03 , SN: FTX1519ALPV
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC15160ZA5
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V02 , SN: QCS1514H0BM
Router#sh diag
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 5 ports
        Port adapter is analyzed
        Port adapter insertion time 1y11w ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15170E4P
        Hardware Revision        : 1.0
        Part Number              : 73-11835-06
        Top Assy. Part Number    : 800-30794-03
        Board Revision           : D0
        Deviation Number         : 113332
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V03
        CLEI Code                : CMMBL00ARA
        Processor type           : C2
        Chassis Serial Number    : FTX1519ALPV
        Chassis MAC Address      : e8b7.48ad.92d0
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 31 37 30 45 34 50 40
          0x10: 06 16 41 01 00 82 49 2E 3B 06 C0 46 03 20 00 78
          0x20: 4A 03 42 44 30 88 00 01 BA B4 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 33 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4C 30 30 41 52
          0x50: 41 09 C2 C2 8B 46 54 58 31 35 31 39 41 4C 50 56
          0x60: C3 06 E8 B7 48 AD 92 D0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-02
        Deviation Number         : 0
        PCB Serial Number        : QCS1514H0BM
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V02
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 02 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 35 31 34 48 30 42 4D 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 32 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
          0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
          0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
          0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
          0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
          0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC15160ZA5
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
        Version Identifier       : V01
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 35 31 36 30 5A 41 35 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router#sh int gi0/1
GigabitEthernet0/1 is down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is e8b7.48ad.92d1 (bia e8b7.48ad.92d1)
  Description: < >
  Internet address is < >
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     2 packets input, 468 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 20 interface resets
     0 unknown protocol drops
     20 lost carrier, 0 no carrier, 0 pause output
Router#sh int gi0/2
GigabitEthernet0/2 is administratively down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is e8b7.48ad.92d2 (bia e8b7.48ad.92d2)
     0 packets input, 0 bytes, 0 no buffer
     1 lost carrier, 0 no carrier, 0 pause output
Is the other end supports auto-negotiation of speed ? if not hardcore the duplex and speed setting on the interface
try moving to gi 0/2 if this doesn't help
That's what my original question was.
I know it will come up if I move it to gi0/2, but what is it that I have to do for the connection at gi0/1 to come up?
Right now don't assume "media type is no media" is the reason for your link not coming up. This port is the one which supports both Rj45 and SFP. the other 2 ports only RJ45
Gi 0/1, you need to configure media-type as Rj45 because your link is copper. You need to configure duplex and speed, if the other end is not supporting auto-negotiation.
If this doesn't work try moving the link to gi 0/2 and check if it works
I had tried configuring media type as rj45/sfp and it did not work. Tried different speed/duplex settings as well.
I will see if moving the link over to gi0/2 helps.
Yes. Please move to gi 0/2 and check
I have moved the link to gi0/2, but still the link does not come up
Sandeep Choudhary
Hi Kashis,
Some gigabit interfaces on Cisco support RJ-45 (copper) and SFP (fiber) operation.
The command media-type has to be used to switch between the two media types.
The example below shows how to configure the media-type with this command.
media-type configuration example:
interface Gigabit0/1
media-type rj45
(UTP)
or
media-type sfp
(fiber)
and then try
Please rate if it helps.
gi0/2 does not have media-type option...gi0/1 has, but my link is on gi0/2 now.
