Features of 40Gb Ports on Cisco 96xx, 95xx,94xx
gp1200x
Level 2
Level 2
Quick question based on reading material. Can I assume the following....I can take a new 40Gb interface and use an adapter to change the interface to a single SFP+ (10Gb) interface.  This is a one for one port connection.   The 40Gb to 4 10Gb interfaces is where I need clarification. Does these adapters simply take a 40Gb interface and create a 4 port etherchannel connection to another device, which means all four ports are dedicated for this specific bundled connection to another device?  In other words this does not give me the ability to use this adapter type to create four separate unique 10Gb connections to different switch / device entities - correct?
Leo Laohoo
As far as I'm aware, yes.
