Nexus 9k VPC to Catalayst
alistair993
Hello people,
In industry I have only seen VPC deployments where Nexus switches are all using VPC and configured back to back (for example, 4 Nexus switches interconnected and configured all with VPC).
I have recently been labbing a scenario of having a dual pair of Nexus 9ks with VPC configured to a single downstream Catalyst (non-VPC) switch which has a regular port-channel configured. I managed to get this working although I had to force channel-group mode to ON for physical ports on both sides.
My question is does anybody have real life experience of this type of deployment working? Has anybody also configured this downstream to a pair of non-VPC switches?
Image below for example:
Mark Malone
yes ,It should also work with LACP ,its standard enough setup , if you have switches in the DC that dont support VPC like catalyst switches
nazimkha
If the catalyst switches can do VSS then you can have vPC on one side and VSS on the other, something similar to back to back vPC
more info in this post
https://community.cisco.com/t5/switching/vss-core-and-vpc-distrubution/td-p/3064758
