FEX Daisy Chaining?
derek.sorci
Community Member
Can multiple Cisco FEXs be daisy-chained together, or does each individual FEX have to connect directly to my Nexus 7K chassis?
Reza Sharifi
FEXs have to connect directly to a parent switch (7k, 6k, 5k).
bdudas
Community Member
Interfaces on the 2K are intended to be host ports only and are automatically set to spanning-tree port type edge at setup. The spanning-tree port type can not be changed on the 2K and any BPDU's received will send that port into a errdisable state. It is possible to connect one 2k to multiple upstream 5K or 7K's in a virtual port-channel scenario.
