FEX in offline state
jay.yobbagy
I have a N2232P connected to my Nexus 7k. We are running version 6.2(6b) and from what I have read it should be supported. The FEX was in a connected state for about 10 minutes then went to offline
sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
---       --------               Offline    N2K-C2232PP-10GE   SSI19110624
Here is the config
fex 101
  pinning max-links 1
  description FEX0101
  type N2232P
  interface port-channel111
    switchport
    switchport mode fex-fabric
  fex associate 101
 interface Ethernet3/28
  switchport
  fex associate 101
  channel-group 111
  no shutdown
interface Ethernet3/29
  switchport
  fex associate 101
  channel-group 111
  no shutdown
InayathUlla Sharieff
To which module is this Fex connected to (M/F series)?
show feature-set
and also check whats the epld is its old try to upgrade the same. ( show version module X epld) cmd will show you the version . Min version to support for this is 5.1.
Inayath
I am new to nexus, so i dont know how find the M/F series module connected ? I am using N5K does this applicable to to 5K or only for 7K.
sh module
Mod Ports Module-Type                         Model                  Status
1   48    Nexus 5672UP Supervisor             N5K-C5672UP-SUP        active *
2   6     Nexus 6xQSFP Ethernet Module        N5K-C5672UP-M6Q        ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    7.1(0)N1(1b)    2.0     --
2    7.1(0)N1(1b)    2.0     --
 sh feature-set
Feature Set Name      ID        State
fabricpath             2          uninstalled
fabric                 7          uninstalled
virtualization         5          uninstalled
and the show version module X epld command is not working in this switch
 sh version ?
  <CR>
  >         Redirect it to a file
  >>        Redirect it to a file in append mode
  fex       Show fex software version
  image     Show the software version of a given image
  internal  Internal commands
Hello
sho fex detail
sh interface fex-fabric
Kind Regards
Paul
