How to control unwanted UDP traffic (Broadcast & Multicast) on Cisco Router 2911?
Varun Luthra
Dear Experts,
Please suggest, we are getting UDP traffic either broadcast or multicast in router 2911 which cause 95%+ utilisation of the router. And we got error in link and business impact due to this. Company has stock exchange business and nano sec downtime worries for us. Please suggest how to control unwanted traffic coming in to cisco router 2911?
Other surprising thing, servers communicated with through LAN network only but why Router CPU utilisation got increased? Sharing router configuration if you found some missing or over configuration which helps to understand better. Highly appreciate your suggestion.
Current configuration : 6715 bytes
! Last configuration change at 09:16:50 IST Fri Nov 2 2018
! NVRAM config last updated at 15:08:12 IST Wed Oct 31 2018
version 15.2
hostname MUMBAI-NSE
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.152-1.T4.bin
boot-end-marker
no logging on
enable password NNNNNN
no aaa new-model
clock timezone IST 5 30
no ipv6 cef
ip multicast-routing
ip flow-cache timeout active 1
ip cef
no mpls ip
license udi pid CISCO2911/K9 sn FGL151912YC
license boot module c2900 technology-package datak9
redundancy
ip ftp username itsdc
ip ftp password jhjytg
class-map match-all SQOS
 match access-group name sgx
class-map match-all qos2
 match access-group name file
class-map match-all other
 match access-group 121
 match access-group 120
policy-map FILE
 class qos2
  bandwidth 800
policy-map BQOS
 class qos
  bandwidth 40000
  queue-limit 1000 packets
 class other
  bandwidth 5000
  queue-limit 10 packets
policy-map SQOS
 class SQOS
  priority level 1
 class other
  priority level 2
policy-map SGX
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description NSE-BSE
 ip address 172.16.18.2 255.255.255.252
 ip pim sparse-dense-mode
 ip flow ingress
 ip flow egress
 ip ospf dead-interval minimal hello-multiplier 3
 load-interval 30
 duplex auto
 speed 100
 service-policy output BQOS
interface GigabitEthernet0/1
 description NSE-GGN
 ip address 10.95.253.81 255.255.255.252
 ip flow ingress
 ip flow egress
 load-interval 30
 duplex full
 speed auto
interface GigabitEthernet0/2
 description LOCAL-LAN
 ip address 172.25.40.100 255.255.0.0
 ip access-group 101 in
 ip accounting output-packets
 ip flow ingress
 ip flow egress
 ip virtual-reassembly in
 ip route-cache same-interface
 ip route-cache policy
 duplex auto
 speed auto
interface FastEthernet0/0/0
 description NSE-DGCX
 ip address 172.16.26.1 255.255.255.0
 ip access-group 130 in
 ip flow ingress
 ip flow egress
 load-interval 30
 duplex auto
 speed auto
 service-policy output SQOS
interface FastEthernet0/1/0
 description NSE-MCX
 ip address 172.16.20.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1/1
 description NSE-SGX
 ip address 172.16.27.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/2/0
 description NSE-CME
 ip address 1.29.75.9 255.255.255.248
 duplex auto
 speed auto
interface FastEthernet0/2/1
 no ip address
 shutdown
 duplex auto
 speed auto
router ospf 2
 network 10.95.253.81 0.0.0.0 area 0
 network 172.16.18.0 0.0.0.3 area 0
 network 172.16.20.0 0.0.0.3 area 0
 network 172.16.20.0 0.0.0.255 area 0
 network 172.16.23.0 0.0.0.3 area 0
 network 172.16.26.0 0.0.0.255 area 0
 network 172.16.27.0 0.0.0.255 area 0
 network 172.25.0.0 0.0.255.255 area 0
 network 192.168.16.0 0.0.0.255 area 0
 network 192.168.150.0 0.0.0.255 area 0
 maximum-paths 2
ip forward-protocol nd
ip pim rp-address 10.95.25.82
ip pim autorp listener
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/1
ip flow-export version 9
ip flow-export template timeout-rate 1
ip flow-export destination 191.191.191.52 9996
ip flow-top-talkers
 top 40
 sort-by bytes
 cache-timeout 20000
ip route 1.29.7.0 255.255.255.252 172.16.2.2
ip route 1.50.7.0 255.255.255.248 1.29.7.11
ip route 10.29.7.0 255.255.255.0 1.29.7.11
ip route 192.168.1.10 255.255.255.255 10.95.25.82
ip route 192.168.1.0 255.255.255.0 192.168.1.1
ip route 192.168.6.0 255.255.255.0 10.95.25.82
ip access-list extended file
 permit tcp any any eq 445
ip access-list extended other
 deny   udp any any eq 45000
 deny   udp any any eq 45002
 deny   udp any any eq 45003
 permit ip any any
ip access-list extended sgx
 permit udp any any eq 45000
 permit udp any any eq 45002
 permit udp any any eq 45003
 permit tcp any any eq 1801
no logging trap
access-list 101 deny   udp any any eq 9999
access-list 101 deny   udp any any eq 34074
access-list 101 deny   udp any any eq 34330
access-list 101 deny   udp any any eq 34586
access-list 101 deny   udp any any eq 5450
access-list 101 deny   udp any any eq 5440
access-list 101 deny   udp any any eq 45446 log
access-list 101 deny   udp any any eq 80 log
access-list 101 deny   udp any any eq 17742 log
access-list 101 deny   udp any any eq 50554 log
access-list 101 deny   udp any any eq 56955 log
access-list 101 permit ip any any
access-list 110 deny   tcp any any eq 3389
access-list 110 deny   tcp any any eq 445
access-list 110 permit ip any any
access-list 120 deny   ip host 172.25.45.21 any
access-list 120 deny   ip host 172.25.45.52 any
access-list 120 deny   ip host 172.25.45.18 any
access-list 120 permit ip any any
access-list 120 deny   tcp any any log
access-list 120 deny   udp any any log
access-list 120 deny   ip host 172.25.45.3 any
access-list 121 deny   udp any any eq 45000
access-list 121 deny   udp any any eq 45002
access-list 121 deny   udp any any eq 45003
access-list 121 permit ip any any
access-list 121 permit ip host 172.25.45.5 any
access-list 121 permit ip host 172.25.45.21 any
access-list 121 permit ip host 172.25.45.18 any
access-list 121 permit udp any any
access-list 121 permit udp any any eq 45000
access-list 121 permit udp any any eq 45002
access-list 121 permit udp any any eq 45003
access-list 121 deny   udp any any log
access-list 121 deny   ip host 172.25.45.8 any
access-list 130 deny   udp any any eq 9999
access-list 130 deny   udp any any eq 34463
access-list 130 permit ip any any
access-list dynamic-extended
snmp-server community public RW
snmp-server ifindex persist
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password OKIJ***&%%
 login
 transport input all
line vty 5 10
 password SAD$$#@
 login
 transport input all
scheduler allocate 20000 1000
end
11 Replies 11
what does the rest of your network/topology look like ? You need to find out first where the broadcast and multicast traffic comes from...
Our company detailing in Stock exchanges, so it works only on Broadcast and Multicast packets. But one thing still i unable to understand, all communications happened with in LAN network only but why router utilisation goes high up to 98% and sometimes hit 100%. We have checked all packets including broadcast & multicast but we cant blocked or deny any because if we do we don't know where it got affected in the applications or business.
My worries how to control Router CPU utilisation because router do not need to do anything for internal communication.
Varun
johnd2310
Level 8
Level 8
have you checked what is causing the cpu to spike? Check the TTL of the multicast stream when it hits the router. You might need to capture the traffic as it enters the routes to see the TTL.
How large is the multicast stream passing through that router?
John
**Please rate posts you find helpful**
dbeattie
Obviously, you need to be aware that the 2911 is not a very high throughput router. I note that you are running seven interfaces at 100Mbps or higher, so there is a definite possibility that you could exceed the forwarding capacity of the device.
Hope this helps,
Dave
Yes, it could be possibility. We have 6 different ISP's P2P links from different countries terminated on 2911 router and few links more than 10 Mbps and few 48 Mbps links. And everyone using the same Database and applications running under intranet. All communication happening between LAN network only but why Router CPU utilisation goes high and touch 98% and even sometimes 100%. Still, unable to find the solution.
Appreciate your suggestions.
Thanks & Regards,
Varun Luthra
post the output of:
show processes cpu sorted | ex 0.00
MUMBAI-NSE#sh processes cpu sorted | exclude 0.00
CPU utilization for five seconds: 98%/52%; one minute: 94%; five minutes: 51%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
128 121348928 217679514 557 44.39% 43.28% 22.58% 0 IP Input
302 1857916 36103274 51 0.55% 0.52% 0.50% 0 OSPF-2 Hello
6 512812 112661 4551 0.39% 0.06% 0.05% 0 Check heaps
285 252 117 2153 0.31% 0.11% 0.03% 390 Virtual Exec
99 617608 99619022 6 0.23% 0.20% 0.18% 0 Ethernet Msec Ti
279 92760 8036450 11 0.07% 0.02% 0.01% 0 IGMP Input
280 182696 17186564 10 0.07% 0.06% 0.07% 0 PIM Process
227 128684 24756346 5 0.07% 0.02% 0.01% 0 MMON MENG
95 87756 1584436 55 0.07% 0.02% 0.02% 0 BPSM stat Proces
296 259516 39297692 6 0.07% 0.08% 0.07% 0 MFIB_mrib_write
65 187972 794762 236 0.07% 0.09% 0.08% 0 Per-Second Jobs
CPU utilization for five seconds: 99%/51%; one minute: 96%; five minutes: 61%
128 121416644 217697733 557 45.83% 44.54% 27.32% 0 IP Input
302 1858488 36106392 51 0.47% 0.52% 0.50% 0 OSPF-2 Hello
285 344 140 2457 0.31% 0.10% 0.05% 390 Virtual Exec
99 617836 99627824 6 0.23% 0.20% 0.18% 0 Ethernet Msec Ti
280 182780 17188128 10 0.07% 0.06% 0.07% 0 PIM Process
65 188060 794833 236 0.07% 0.09% 0.08% 0 Per-Second Jobs
227 128720 24758559 5 0.07% 0.02% 0.01% 0 MMON MENG
279 92816 8037173 11 0.07% 0.02% 0.01% 0 IGMP Input
296 259592 39301179 6 0.07% 0.08% 0.07% 0 MFIB_mrib_write
as Paul suggested, did you remove all 'log' keywords from your access lists ? Anything logged is process switched, which can cause high CPU and IP Input counter increases...
Hello
Your cpu interrupt level is very high and its related cpu process indicates network traffic flooding the cpu.
Quite a few things that possibly warrant such cpu interrupt utilisation could be your netflow and acl logging, and you have cef enabled but is it applied to the physical interfaces?
suggest:
disable any debugging/span sessions
remove any acl logging
temporary disable netflow/ip accounting
check to make sure you are indeed fast/cef switching
sh debug
sh monitor
sh ip cef
sh cef not-sef switched
sh ip cache
sh ip interface gigx/x | in IP
sh interface gigx/x stats
conf t
un all
no monitor session x
no ip flow ingress
no ip flow egress
no ip flow ingress
no ip flow egress
no ip accounting output-packets
no ip route-cache policy
no ip route-cache same-interface
no ip flow ingress
no ip flow egress
no access-list 101
no access-list 120
no access-list 121
Kind Regards
Paul
Thanks Paul for replying.
Now production is down, so cant do anything. Will check all given commands by tomorrow and reply you after that.
But before implement all this, i have one question. As you mentioned, to apply "no access-list 101", "no access-list 120", "no access-list 121" if i implement this command then i think it will stop communication with specific ports or IP address which may be impact in production environment. Because application team suggest us to block certain ports and IP addresses. So suggest should i proceed or consider something else.
Varun Luthra
Hello
Yes oh course, that was just a suggestion to amend the acl however if you cannot remove the acl from the interface then you can do it whilst its still applied to the interface but you need to know what ace's to remove or to change.
show ip access-list x/x will show the related numbering to each ace entry within that acl.
example:
sh ip access-lists 101
Extended IP access list 101
10 deny udp any any eq 34074
20 deny udp any any eq 34330
30 deny udp any any eq 34586 log <--------------------- change this to remove the logging
40 deny udp any any eq 5450
50 permit ip any any <---------------------- relocate this to the end of the acl
60 deny udp any any eq 5440
70 deny udp any any eq 45446
80 deny udp any any eq 80 log
90 deny udp any any eq 17742
100 deny udp any any eq 50554
110 deny udp any any eq 56955
conf t
ip access-list extended 101
no 30
no 50
Kind Regards
Paul
