Bookmark
Subscribe
8151
Fiber connection between c4503 and c2960x not working
Bernd Ziller
I just tried to establish a fiber connection between a c4503 and a c2960x using glc-lh-sm modules on both sides, but with no success.
Link comes up on the c2960x but not on the c4503.
I tried "speed nonegotiate" on both sides: link comes up on both sides, but no data received on both sides.
A connection between a c2960-24LC-S and the c2960X-24PD-L works fine, as does a connection between the c2960-24LC-S and the c4503.
All on the same ports and modules and also different ports an modules per switch.
Any suggestions on why a connection between the c4503 and the c2960X doesn't work?
23 Replies 23
Same problem here
1) 2960X (GLC-SX-MM-C) to Sup2T/6509E/6848 -> 2960X shows up/up, 6509 down/down
2) 2960X (GLC-SX-MM-C) to 2960X (GLC-SX-MMD) -> both ports up CDP Nei shows the switch
3) Upgrade Software from EX1 to EX3 -> same behaviour
Switch#show version | incl EX3
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX3, RELEASE SOFTWARE (fc1)
System image file is "flash:/c2960x-universalk9-mz.150-2.EX3.bin"
*    1 52    WS-C2960X-48FPD-L  15.0(2)EX3            C2960X-UNIVERSALK9-M
Switch#
Switch#show int gi1/0/50 capabilities
GigabitEthernet1/0/50
  Model:                 WS-C2960X-48FPD-L
  Type:                  1000BaseSX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
Switch#
Switch#show idprom interface gi1/0/50
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x01 0x20 0x40 0x0C 0x00
Encoding              :   0x01
BR_Nominal            :   0x0D
Vendor Name           :   CISCO-PROLABS
Vendor Part Number    :   GLC-SX-MM-C
Vendor Revision       :   0x20 0x20 0x20 0x20
Vendor Serial Number  :   P1A24111
Didn't open TAC case yet
Hi all,
I've got the same problem.
Bug: CSCuj70291
1 gig uplink on WS-C2960X-48LPD-L does not link up with 4306, 4448-GB
Symptom:
Uplink port with glc-sx-mm,glc-lh-sm not coming up between WS-C2960X-48LPD-L and any catalyst 4500 with WS-X4448-GB-SFP and WS-X4306-GB. When speed no negotiate is enabled, link comes up, but no traffic.
This is observed with catalyst 6500 line cards as well.
Conditions:
Workaround:
None
Bug-fix will be release on 18th of Nov.
Regards, Alfred
I can't believe this bug!
I can see the 2960 BU is doing a "bang up" job in Quality Control.
samuel.heinrich
Same issue here. Link does not come up.
Side A
WS-C4506 (WS-X4306-GB linecard with 1000BaseSX GBIC)
Side B
Cisco Catalyst 2960X-48FPS-L* (GLC-SX-MM SFP)
All GBIC/SFP/Linecard Ports were replaces with no effekt. If we configure "speed nonegotiate" then we can see the LED turns green and  link shows connected but traffic counters remain zero.
I can assure you that there are no issues with the cabling or SFP moduels, if we replace the 2960x with a 2960s (same config) the link works like a charm!
It looks like this issue is not fixed in EX3, at least not on the WS-C2960X-48FPS-L plattform!
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 11-Sep-13 02:04 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.0(2r)EX, RELEASE SOFTWAR
E (fc1)
AS.... uptime is 23 hours, 33 minutes
System restarted at 12:33:41 MEST Tue Nov 12 2013
System image file is "flash:c2960x-universalk9-mz.150-2.EX3.bin"
Hi all,
bug CSCuj70291
Solution provided with EX4 (for C2960X)
Release date 18.11.2013
Regards, Alfred
Correction:
bug CSCuj70291
Solution will be provided with EX4 (for C2960X)
Planned release date 18.11.2013
Regards, Alfred
hmm can't find the bug CSCuj70291 in the EX4 release note..
but this at least this one:
Caveats Resolved in Cisco IOS Release 15.0(2)EX4
CSCuj74167
Gigabit link from WS-C2960X-48FPD-L not coming up when using GLC-SX-MM.
There is no workaround.
EX4 fixed it today for me.
A painful bug causing a lot of issues.
My main concern is that i suffered from painful bugs in the last 3-4 implementation of new cisco products.
There was no implementation without a Cisco TAC case
Hi all,
exactelly, bug CSCuj74167 in the release notes is a duplicate of bug CSCuj7029.
Regards, Alfred
