fiber switch
Moudar
I wonder waht models do replace the WS-C4500X-16 and WS-C3850-12S.
What is important is that all ports are fiber ports.
What are Cisco switches (Layer 2) that only are 1GB fiber ports.
I could only find SG-350 10-port fiber switch! Is there any other model that is IOS or IOS-XE ?!
8 Replies 8
 If you look at the End of Life anouncement from Cisco they inform you what would be the replacement.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/eos-eol-notice-c51-743098.html
Reza Sharifi
There are a couple optons with 9300. See table-2 in this link:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
C9300X-12Y
12 port 25G/10G/1G SFP28
C9300-24S
24 1G SFP
Moudar
What about a cheaper fiber switch 1GB which will be used as normal switch but for fiber cables.
What other models do Cisco offer that are cheaper than 9300 & 9500?
None.  9300/9300X is the "cheapest" option.
Personally, I'd look at refurbished units due to OS stability reasons.
Where do these refurbished units  being sold? From Cisco direct or how?
What refurbished units models are recommended for normal fiber switch and for replacement of 4500x and 3850
