Filtering multicast groups
vaniello
What is the best way to filter multicast groups on a router between a provider's network and ours? We are using AutoRP between the networks.
I have a set of multicast groups that I would like to permit and filter the rest. I tried using an access-group on the interface and is added too much CPU overhead. Is there a better way to filter the groups?
Thanks.
V/
vladrac-ccna
Level 9
Level 9
Hello Vaniello,
I believe the best way would be filtering the groups you dont want to join.
If you control the RP maybe you should use:
ip pim accept-rp {rp-address | auto-rp} [access-list]
Or simply dont allow any host to join the groups you dont want to receive traffic:
ip igmp access-group
To restrict hosts (receivers) on a subnet to joining only multicast groups that are permitted by a standard IP access list or to restrict hosts (receivers) on a subnet to membership to only the (S,G) channels that are permitted by an extended IP access list, use the ip igmp access-group command in interface configuration mode.
ip igmp access-group access-list
Let me know if this helps.
Vlad
This is a router to router connection where I want to filter the groups I receive from the remote router. Will the IGMP access groups filter multicast groups between two routers, versus hosts on a LAN?
Thanks.
V/
Hello
Are you doing multicast sparse-mode using auto RP?
there should be no multicat traffic to your router if no host joins the multicast groups.
Vlad
I am using sparse-dense mode with auto RP. I was under the impression that I had to use sparse-dense mode.
Using the "ip multicast boundary" command I seem to be able to filter the groups on the connection between my router and the providers.
Unfortunately, the blocked multicast groups still seem to show up in the mroute table:
(*, 224.0.5.220), 00:13:32/00:03:02, RP 198.140.33.2, flags: SP
Incoming interface: FastEthernet1/0.10, RPF nbr 10.131.0.38
Outgoing interface list: Null
While hosts can not join this group, it clutters the mroute table.
V/
