Finding the default gateway of the switches (help!, for an assignment)
Tysonvd
I need to find the default gateway for the pc's and the switches (for uni). I have done the pc's as they were pretty simple. As this is a .pka task file i did not setup any of the network. I have run the following commands to see if i could find it out but am not able to:
-"show ip interface brief"
-"show start"
-"show run"
help.... just need the default gateway for S1 and S2, would it be the router ip?
in switches, get #show run
out put and check for # ip default-gateway command. use the ip address after that command.
Good luck
KB
6 Replies 6
Good luck
KB
Yeah under show run and show start, there is no command stating "ip default-gateway" this means there is no default gateway set?
default-gateway set for Layer 2 switches. you can also look with below command
show ip route
show run | in route
BB
Wow, emailed lecturer and they forgot to set an ip for the default gateway, thanks anyway guys
I did find that in pocket trace you can use
do show run | include gateway if you are in config mode
or
show run | include gateway  - in privilege mode.
Hope you find that helpful.
AG - Campbell
sh run | i default-gateway
