firmware upgrade path for C9300
bbb bbb
Hi Everyone,
We have new C9300-48U in our environment and we are looking to upgrade these switches to new releases as we have also discovered vulnerabilities with the current IOSXE.
as of this writing the switch image version is
Base from the information I got from Cisco sites, the suggested release version is Amsterdam 17.3.3
C9300-48U-A
Software Download
Should I directly upgrade it to 17.3.3? or is there any other way to do upgrade to current or stable release?
Appreciate if any links can be shared here to point me to right direction.
marce1000
 - Check Release Notes for the intended version you want to install, items like that are usually explained and or elaborated at (look for items concerning installation notes and related).
 M.
thank you for the information. will take note of that.
Leo Laohoo
Direct upgrade to 17.X.X is supported however, read the Release Notes very carefully.
Thank you for the information. Will take note of that as well.
