flapping between port two interface on the same switch
CISCOTUMBA
Frequent Visitor
Frequent Visitor
ello everyone,
I'm getting falpping between port  Gi1/0/16 and Gi1/0/23. Here is my config on the those interface:
s16-smc-mdf-3750#sh run int gi1/0/16
Building configuration...
Current configuration : 206 bytes
interface GigabitEthernet1/0/16
description AP SMC_S1.31
switchport trunk allowed vlan 51-54,56,60,70,80,90,504
switchport mode trunk
spanning-tree portfast
end
s16-smc-mdf-3750#sh run int gi1/0/23
Current configuration : 203 bytes
interface GigabitEthernet1/0/23
description ICU-AP
switchport trunk allowed vlan 51-54,56,57,60,70,80,90,504
end
The interfaces are configured for APs. I’m using the same interface configuration on 120 other APs, and this issue is only happening with these two.
Could it possibly there is a bad AP?
Any help would be much appreciated.
6 Replies 6
Mark Elsen
   - @CISCOTUMBA    For access points , that is normal ; if a client starts roaming between them ,
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
It could be a wifi client that is roaming back and forth between the APs.
So on one hand it could be normal, but can also be an indicator that this client is experiencing wifi issues, maybe due to equally bad signal to both APs or something else.
Is this happening to only mac address or multiple mac addresses between these APs?
Please mark helpful answers & solutions
CISCOTUMBA
Frequent Visitor
Frequent Visitor
Hello Jonatan,
I didn’t check whether the MAC address is different, but they are experiencing Wi-Fi issues. Bouncing the interface resolves the problem, but after a few days the same issue occurs again.
pieterh
there is a mismatch in the "allowed vlan"  list of both AP's
do you have an explicit reason for this? if not I advise to keep them equal.
@pieterh the missing vlan is just and disabled SSID VLAN so it shouldn't matter.
pieterh
Could be.
To be sure : also no dynamic vlan assignment in use ?
