Flash clean up unused files in WS-C3850-12S
Hello
What is the command to do the cleanup in flash . Below are the flasj files,i need to remove files which are unused. switch model is WS-C3850-12S
2 2097152 Dec 28 2022 11:54:11.0000000000 +00:00 nvram_config
3 79110340 Apr 25 2015 12:31:27.0000000000 +00:00 cat3k_caa-base.SPA.03.03.04SE.pkg
4 6521532 Apr 25 2015 12:31:28.0000000000 +00:00 cat3k_caa-drivers.SPA.03.03.04SE.pkg
5 34530288 Apr 25 2015 12:31:28.0000000000 +00:00 cat3k_caa-infra.SPA.03.03.04SE.pkg
6 34856268 Apr 25 2015 12:31:28.0000000000 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EZ4.pkg
7 25172880 Apr 25 2015 12:31:28.0000000000 +00:00 cat3k_caa-platform.SPA.03.03.04SE.pkg
8 77445952 Apr 25 2015 12:31:28.0000000000 +00:00 cat3k_caa-wcm.SPA.10.1.140.0.pkg
9 1247 Apr 25 2015 12:31:35.0000000000 +00:00 packages.conf
10 1104 May 19 2021 14:42:15.0000000000 +00:00 vlan.dat
11 407449018 Feb 25 2020 14:34:40.0000000000 +00:00 cat3k_caa-universalk9.16.06.07.SPA.bin
12 4096 Dec 28 2022 11:49:38.0000000000 +00:00 .installer
6 Replies 6
del flash:/file name
The flash: is usually read only. Cant just delete it.
OK Any other cleanup command to do all unused file with single command ?
there is one but I think it risky it can delete all file, used and unused,
so I prefer your del flash:
In IOS-XE version 3.X.X, the command is:
software clean force
Richard Pidcock
Depends on what version of code you are running.  You might also try "install remove inactive"
What version of code are you running?
Richard W. Pidcock
