flash is read only,unable to upgrade IOS for 2621XM router
vinayjaiswal
Level 3
Level 3
I am not able to upgrade the IOS for 2621 router.Please advise.
------------------ show version ------------------
IOS (tm) C2600 Software (C2600-IK8O3S-M), Version 12.2(11)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 01-Aug-02 12:47 by ccai
Image text-base: 0x8000809C, data-base: 0x818188F4
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Z0-2621-MALVIYANGR uptime is 3 days, 10 hours, 50 minutes
System returned to ROM by reload at 04:05:57 IST Sun Oct 19 2008
System restarted at 00:08:49 IST Mon Oct 20 2008
System image file is "flash:c2600-ik8o3s-mz.122-11.T.bin"
cisco 2621XM (MPC860P) processor (revision 0x100) with 60416K/5120K bytes of memory.
Processor board ID JMX0643L2B5 (879884371)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Device not programmable)
------------------ show file systems ------------------
File Systems:
Size(b) Free(b) Type Flags Prefixes
29688 20242 nvram rw nvram:
- - opaque rw null:
- - opaque rw system:
- - opaque ro xmodem:
- - opaque ro ymodem:
- - network rw tftp:
* 50331648 34523140 flash ro flash:
- - network rw rcp:
- - network rw pram:
- - network rw ftp:
- - network rw scp:
Please help.
6 Replies 6
adhityakarthik
Could you please let me know the below points
1)Total size of the flash
2) current size of the IOS
3)Proposed(NEW) size of the IOS
what is the DRAM size
and please let me know what error message your getting and also please post the error
thanks
Adhi
total size of flash is 48MB
Current size is 16 MB
Proposed(NEW) size of the IOS is 12 MB
DRAM Size is 64MB
Error is it says Device is Read only
Vinay
Can you please attach the show tech-support log please.
Omar
Also please attahced erros logs, it will be usefull
regds
Adhi
Plz provide the output of.
show flash
show ver and the name of the ios u want to upgrade.
Also let us know how are u dooing the upgraded the doc u are refering.
Pravin
Vinay
I have done some looking and I do not find any indication of what would cause the flash in 2621XM to be read only. But that does seem to be the case with your router. I believe that I had a similar problem a while back (different platform but its flash was marked read only). If my memory is correct I resolved the issue by doing a format of the flash, which erased all content on the flash, but produced a flash that I could write to. So I suggest that you try to format this flash and see if the result allows you to put a different IOS onto the flash.
Rick
Rick
