01-25-2021 01:44 PM
Hi All-
Looking for some guidance on how to deal with what i assume is a flash corruption issue on an old 3750 stack. It won't save the startup config.
c3750-5e15-32.50.csc#cop run star
Destination filename [startup-config]?
nv_done: unable to open "flash:/multiple-fs.new"private-config file open failed (Not enough space)
c3750-5e15-32.50.csc#dir flash:
Directory of flash:/
4 drwx 64 Feb 28 1993 18:56:31 -06:00 c3750-ipbasek9-mz.122-46.SE
7 -rwx 616 Jul 18 2014 13:02:53 -05:00 vlan.dat
15998976 bytes total (6792192 bytes free)This is a stack of 5 switches. I looked at each one and they all look like there is room. i ran fsck on all of them and they all report clean.
I feel like this is gong to take up a lot of my time! Any suggestions would be appreciated!
01-25-2021 01:56 PM
Maybe a bad flash as this bug supposed to be fixed in 12.2(44) according to the bug release notes:
You may want to try and save the config to a TFTP server and try to reboot the stack in a maintenance window.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsl06568/?rfs=iqvred
01-25-2021 04:05 PM - edited 01-25-2021 04:06 PM
Post the complete output to the following command:
dir nvram:
sh boot
01-26-2021 03:11 AM
Format the flash and load stable IOS 12.2.55-SE12
=====️ Preenayamo Vasudevam ️=====
