06-24-2021 03:53 AM - edited 06-24-2021 03:53 AM
Hello All,
Just over the IOS upgrade from 152-1.SY5 to .155-1.SY6 on a cisco 6880-X box, but the old netflow commands seem to be not working anymore. Any idea how to apply netflow ? I don't understand this beaviour.
Thanks in advance!
(config-flow-monitor)#interface Port-channel22
(config-if)# ip flow monitor IPv4-FlowMonitor input
% Flow Monitor: Flow Monitor 'IPv4-FlowMonitor' cannot be applied because of the following error(s):
- Field 'intf output' cannot fit in the key
Flow Recorder Config:
flow record FREC
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
match routing vrf input
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect ipv4 source prefix
collect ipv4 source mask
collect ipv4 destination prefix
collect ipv4 destination mask
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
Solved! Go to Solution.
06-24-2021 04:29 AM
is this layer 2 Port-channel or layer 3 ?
Look at the syntax changed :
https://pitstop.manageengine.com/portal/en/community/topic/failed-to-netflow-v9-on-cat3850-device
06-24-2021 05:05 AM
L3, and the linked solution did work. Thank you for your valuable comment!
06-24-2021 04:29 AM
- FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk36254
M.
06-24-2021 05:04 AM
Yes, the strange things is that my ios version is not mentioned under the affected release.... But yes, I see the issue , and it seems the wuality of cisco softwares is going down... Anyways, thanks for your help!
06-24-2021 04:29 AM
06-24-2021 05:05 AM
