format flash problem
abdulwalicisco7
Community Member
Dear  all
please I want  to copy image to router 2811 flash  but there is problem
and when I try to fromat  the flash  an error  as the following  show :
Router#format  flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:".  Continue? [confirm]
Enter volume ID (up to 64 chars)[default flash:]:
Current Low End File System flash card in flash: will be formatted into DOS File
System flash card!  Continue? [confirm]
Error unable to set flags for flash.
%Error formatting flash: (No device available)
Router#
*Feb 21 22:35:22.527: %IFS-3-FSDUP: Failed to add flash, filesystem prefix exist
s,  -Traceback= 0x4182A518 0x41E9F5A0 0x40131690 0x40131708 0x4029A368 0x41EA3E0
C 0x41EB9D38 0x4187815C 0x4189D174 0x431DDF2C 0x431DDF10
please, how can i fix this problem.
7 Replies 7
Reza Sharifi
Do you have any file in flash:
can you post "sh flash"?
Reza
I found this:
Error Message
%IFS-3-FSDUP : Failed to add [chars], filesystem prefix exists
Explanation   An internal software error occurred.
Recommended Action   If the message recurs, copy the error message exactly as it appears on the console or in the system log, and report it to your Cisco technical support representative.
So your flash card might have an error. Try to post more information like Reza suggested.
Ian
Dear Raza;
this is the boot show
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80014e20
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0x36b7c5c
Error : compressed image checksum is incorrect 0x3E652FD1
        Expected a checksum of 0xEC001416
rommon 1 >
That does not look good. Take the flash card out and try it in another router but I think the card itself is damaged/corrupt.
Try to format it with another application. Most card readers are able to take flash cards. But after formatting you will need to reload the IOS via tftp or xmodem. Here are the links:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
If after all that it doesn't work, card is probably corrupt and you will need a new card.
Ian
Sounds like the IOS is corrupt and has a bug.  Can you eject the CF and put it into a multi-card reader.  Copy a DIFFERENT IOS version into the CF and boot the new IOS?
Michael Simon
Level 4
Level 4
Hi Abdulwali,
To recap, the IOS image on this CF is corrupted.  Possibly the CF is corrupted.
First look at this Field Notice (FN):
http://www.cisco.com/en/US/ts/fn/620/fn62573.html
Your capture is not the classic result for this FN but there are some similar indications:
If your CF matches the FN follow its instructions.  If not follow this action plan:
The recommended action plan is as follows:
1.  Take the CF to a PC and delete the old IOS image and copy a new IOS image onto this CF WITHOUT formatting it on the PC.  Just do a copy.
2.  Try to boot the 2811 with the new copy of the image.
3.  If that does not boot and continues to give indications of a corrupted flash take the CF to the PC, format it, copy a clean IOS image onto it and try to boot the 2811 again.  Formatting a CF for a router on a PC is a dicey thing and usually not recommended.  But it is worth a try at this point.
4.  If it still will not boot, use the instructions provided earlier to TFTP boot the system:
5.  When it is running a clean IOS image, use IOS to format the CF.  If this fails and you have a spare CF disk format it on this system.
6.  If the original CF will not format but the new one will, open a TAC case to have the CF replaced by RMA.
7.  If neither CF will format, open a TAC case to have the 2811 and the CF replaced by RMA.
This process should result in a clean system.
........Mike Simon
abdulwalicisco7
Community Member
Dear all
Thank you  for help,
after  downloading  image file with size 16MB  the flash worked will and the boot was  normaly .
the flash card is 64 MB  the problem was when I used Image file 24MB  or 45MB  , I Use another Flash and same problem .
now its OK  the router is working well ,
and again thanks for all
