Forward UDP broadcast in Nexus 3172
gciotto
I'm specyfing a core L3/L2 switch to connect my servers. One of the applications that will run in those machines uses a protocol which need to retrieve information from the hosts by sending UDP broadcasts in a specific port. As we'll many subnets, I'd like to know if the Nexus 3172 can forward this kind of packets to retrieve data from hosts which aren't connected to the same subnet of the servers.
I believe that the commands needed for this features are ip forward-protocol and ip helper-address.
This related post answers the question for the Nexus 7000 series, but it's quite old.
Could you clarify this point, please?
Gustavo
Andrea Testino
Unfortunately, "ip forward-protocol" is not supported on Nexus 3000s as of yet and there is no timeline identified or an ETA in the roadmap for this feature.
This is somewhat documented (albeit poorly) in https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu60491/?reffering_site=dumpcr for the N9K yet it applies to the N3K as well.
Hope that helps.
- Andrea
- Andrea, CCIE #56739 R&S
Mark Malone
I ony have 2,5,7,9k nexus switches but when i check the 3k series config guide ip dhcp relay is there like the 7ks so that should be ok , there is no helper command on nx-os only dhcp relay
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/security/503_u3_1/b_Cisco_n3k_Security_Config_503_u3_1/b_Cisco_n3k_security_cg_503_u2_2_chapter_01010.html#task_1274310
the ip forward i dont see on any of my switches and i dont see it listed on the 3k config guides either , doesnt look good , maybe someone on a 3k can confirm further
Andrea Testino
Hope that helps.
- Andrea
