Port Channel issue Cisco 3850
mediaos718
I have a port-channel with 4 interfaces. One of the interfaces is flapping. What is weird is that it works for a few hours then it starts flapping then it is suppended. See error msg in the log below:
is not compatible with Gi1/0/5 and will be suspended (speed of Gi2/0/10 is 100M, Gi1/0/5 is 1000M
Derrick Hurley
Check the "show interface" of the interfaces on both sides of the link.  I suspect you have a bad cable or SFP and you'll find input and CRC errors on the port.
9 Replies 9
Derrick Hurley
Ok, I notice the CRC error (Very high) - I will change the SFP and go from there.
Great!  Come back and let us know how it goes.
Julio E. Moisa
You cannot create EtherChannel with different features or capabilities, You need to have same characteristics, speed, duplex etc.
You should have the same speed on both interfaces 100 or 1000Mbps and the same at the other end.
Other cases are:
You cannot create an Etherchannel with FastEthernet on one switch and the other switch with GigaEthernet.
Also you cannot group FastEthernet and GigaEthernet ports on the same switch to build and Etherchannel.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
@Julio E. Moisa
The ports are all GigabitEthernet - Sometimes it works for a couple of hours. I just swapped the SFP - Everything is working (See log below). I am going to wait for a couple of hours to see if the flapping continues.
*Sep 29 05:07:45.593 EDT: %EC-5-COMPATIBLE: Gi2/0/10 is compatible with port-channel members
*Sep 29 05:07:45.683 EDT: %EC-5-COMPATIBLE: Gi2/0/10 is compatible with port-channel members
*Sep 29 05:07:47.585 EDT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/10, changed state to up
*Sep 29 05:07:51.295 EDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/10, changed state to up
Thank you,
Could you please share the configuration of the Portchannel members and interface port channel from both switches.
Thank you
Make sure you clear the counters on the interface too.  That will allow you to see if the CRC errors continue after your SFP swap.  If you continue to get CRC errors, then I would start swapping patch cables.
@ Derrick Yes, I clear the counters of both side.
@ Julio see config below
SW-1#sh run int po100
Building configuration...
Current configuration : 158 bytes
interface Port-channel100
no switchport
vrf forwarding TICKER
ip address x.x.x.x/x
end
SW-1#sh run int te1/5/13
Current configuration : 172 bytes
interface TenGigabitEthernet1/5/13
no switchport
no ip address
channel-group 100 mode active
end
SW-1#sh run int te1/5/14
interface TenGigabitEthernet1/5/14
no switchport
no ip address
end
SW-1#sh run int te2/5/13
interface TenGigabitEthernet2/5/13
no switchport
no ip address
end
SW-1#sh run int te2/5/14
interface TenGigabitEthernet2/5/14
no switchport
no ip address
end
SW-2#sh run int po100
Current configuration : 130 bytes
switchport access vlan 100
switchport mode access
end
SW-2#sh run int gig1/0/9
Current configuration : 165 bytes
interface GigabitEthernet1/0/9
end
SW-2#sh run int gig2/0/9
interface GigabitEthernet2/0/9
end
SW-2#sh run int gig2/0/10
Current configuration : 166 bytes
interface GigabitEthernet2/0/10
end
As I remember you cannot create an Etherchannel with L3 port on one switch and the other end as layer 2.  They should be L3 or L2 on both ends.
Also you could remove the line vrf forwarding TICKER under the member interfaces, because it is managed by the Port channel interface.
SW1
no switchport
end
SW2
end
